Craigslist Find - Is this what I think it is?
   / Craigslist Find - Is this what I think it is? #1
N2DFire
Rocky Mount, VA
Ford 8N, Kioti CK35
Been looking to add a Box Blade to the implement fleet and I found this older posting on CL. Not really sure if it's still available as it's over a month old - but just in case ...
From what I can find on the internet, this looks like an old Gannon Roll Over - yes?
https://lynchburg.craigslist.org/grd/5263453657.html
So the questions:
Is it what I think it is? IF not then what is it?
What things should I look at in person to determine condition?
And where are we on the "fairness" scale with the price?
Oh - one other question - Too much blade for a 35 HP tractor?
As far as condition I'm not scared of surface rust & I know full well paint is just cosmetic - I'm more concerned about stress areas to look for cracks, bad bearings, etc.
Thanks in advance for anything you want to throw out here.
   / Craigslist Find - Is this what I think it is? #2
Your tractor can handle it... I would have them pick it up to make sure that the rollover feature works. Look for bends and cracks - I rarely get an implement that doesn't need some welding.
The price is not too bad...
Attaching photos of it from the Ad...
View attachment 448119View attachment 448120
   / Craigslist Find - Is this what I think it is? #3
Yes it's a box scraper with adjustable scarifiers....nice having them adjustable rather than having to do a lot of undoing/redoing if not. Seems it has already suffered through the break-in process. Attachment of the 3 pt mounting bracket looks like a scab on but appears to be holding. Even if it's not, agree with teg that you may have some touch up welding to do. Otherwise looks like a good husky (heavy.....desirable) unit.
   / Craigslist Find - Is this what I think it is? #4
Check the springs that return the handle to the lock position,mine are broken and a ***** to change.
Thanks for the replies thus far.
I have been basing my guess off of this thread by Brian (MtnViewRanch)
http://www.tractorbynet.com/forums/attachments/98520-gannon-rollover-box-blade-scraper.html
and this Youtube video
I thought so too at first but looking at the above units as well as the current offerings by Woods (bought out Gannon I believe) - that just seems to be their "style"
Product Details
Thanks for all the info. I'll see if I can talk the "Fleet Manager" (aka Dad) into this one and see if it's still available.
   / Craigslist Find - Is this what I think it is? #6
I would see if it's available first... not much work to check first.
   / Craigslist Find - Is this what I think it is? #7
If that Gannon ROBB is still available, just buy it for the $400. Well worth it. Teeth are on the shanks backwards, but not that big of a deal.
I would also say that there is a good chance that even if the cutting edges are worn a bit, they can just be flipped and you have new edges to start with if desired.
Good luck. :thumbsup:
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
2020 Case TR310B Skidloader (RIDE AND DRIVE) (A50774)
2020 Case TR310B...
2015 CATERPILLAR 272D2 WHEELED SKID STEER (A50458)
2015 CATERPILLAR...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A52128)
Ditch Witch 6510A...
2803 (A50460)
2803 (A50460)
2022 BOBCAT T595 SKID STEER (A51242)
2022 BOBCAT T595...
