TRIVA FUN
/ TRIVA FUN #1,001
/ TRIVA FUN #1,003
What has ten cylinders, twenty pistons, two crankshafts, and no valves?
Been in use from 1930's to present day.
That sounds like the Fairbanks Morse two piston per cylinder engines that was used in Submarines. Am I close?
/ TRIVA FUN #1,004
What diesel engine series had spark plugs fired by a magneto? No, these are not glow plugs.
/ TRIVA FUN
There was a radial aircraft engine that had no carburetors. Only RPM control was to turn ignition on & off.
What was it???
/ TRIVA FUN #1,006
Our JD Model A ran on diesel fuel and had spark plugs.
Rhone-Gnome rotary aircraft engine. I think the crank was mounted to the fuselage and the prop was on the crankcase.
Bruce
/ TRIVA FUN #1,008
Marshall Dillon rode Buck on Gunsmoke and after it ended Ben Cartwright rode Buck on Bonanza.
Close enough. Buck the horse was in both shows. Loren Greene like the horse so much he bought it and took it home.
/ TRIVA FUN #1,009
Bruce
Yep and due to the gyroscope effect it would turn sharply one way but very poorly the other.
/ TRIVA FUN #1,011
/ TRIVA FUN #1,012
/ TRIVA FUN #1,013
For some reason it isn't taking the 'reply with quote'
Then the JD used the same system as the one I have in mind except on mine you didn't need to switch back to gas when shutting down.
Harry K
/ TRIVA FUN #1,014
Harry K
We switched back, but I don't know if it was required to. Just how I was told to do it. It has been a long time.
Bruce
/ TRIVA FUN
How long did the Pony Express last??
What put it out of business??
! Very famous partner was whom??
/ TRIVA FUN
It lasted 19 months.
The telegraph put it out of business.
Buffalo Bill was 1 0f the owners.
What was Buffalo Bill's actual name????
In the western TV shows They always talk about the 45 cal. & sow it being loaded in rifles.
Is that correct????
2018 Ford F750 Mechanic Service Truck (A60352)
2018 Ford F750...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2003 JOHN DEERE 310SG BACKHOE (A62129)
2003 JOHN DEERE...
BOX BLADE (A58214)
BOX BLADE (A58214)
CASE IH MAXXUM 115 TRACTOR (A62130)
CASE IH MAXXUM 115...
Kubota M125X (A60462)
