If you have Toolcat questions, ask them here...
/ If you have Toolcat questions, ask them here... #301
Different topic......
I need to run several sets of wires (side cab lights, rotating beacon and backup camera) from on top of the cab into the cab. Has anyone found an easy access point to do this, other than drilling a large hole into the cab body?
Thanks, DEWFPO
/ If you have Toolcat questions, ask them here... #303
I ran ours into the console, then down through the hole that the rest of the harness goes through. You just need to lift that center plastic console, a couple torx screws in the back and bolts under the rubber arm rest.
Thanks, DEWFPO
/ If you have Toolcat questions, ask them here... #304
A94Y11998 Thanks!
Code: 50-54: Swash Plate Not In Neutral
Description:
A Code 50-54 occurs when the Drive Controller detects the Swash Plate sensor is not in the neutral range of 2.2 – 2.8 volts. If a Code 50-54 occurs, drive will be disabled.
Possible Cause:
Hydraulic pump is not physically centered. Refer to the Service Manual.
Signal wire 3550 shorted to a ground or voltage source.
Ground wire 2600 open.
Swash Plate sensor.
Code 50-19 "Swash Plate Sensor Out Of Range High".
Code 50-20 "Swash Plate Sensor Out Of Range Low".
Code 50-35 "Servo Coil Maximum Current".
Code 50-49 "Brake Coil Short To Battery (Coil Return)".
Drive Controller.
Moisture, corrosion, or pushed back pins in the Drive Controller connectors, Swash Plate sensor connector, or wire harness. See Electrical Systems Connector Maintenance in Technical Information.
If the code is intermittent and not on at the time of testing, the cause of the code may not be found at this time. Probable causes may include: loose connections, corrosion, pushed back pins, the controller, the wire harness or a combination of these problems. Refer to Troubleshooting Intermittent Electrical Faults Procedures in Technical Information.
Conditions for Code:check Swash Plate sensor signal wire 3550 for a short to ground or supply voltage. Does wire 3550 check OK?
Go to Step 2. Repair or replace wire harness.
2 Check continuity on ground wire 2600. Does wire 2600 have continuity?
Go to Step 3. Repair or replace wire harness.
3 Place the machine on jack stands. Disconnect the Swash Plate sensor. A Code 50-19 “Swash Plate Sensor Out of Range High” will occur. Warning: Make sure all bystanders and tools are clear of wheels! Start the Tool Cat, do the wheels rotate?
Internal problem with the pump. Replace Swash Plate sensor.
/ If you have Toolcat questions, ask them here... #305
Now that's something I can work with!
Thank you kindly sir!
/ If you have Toolcat questions, ask them here... #306
Sounds like you need a Service Manual and a Parts Manual: Manuals - Bobcat Company
Disregard the "NO STOCK AVAILABLE FOR THIS ITEM"
/ If you have Toolcat questions, ask them here... #307
True story, I just need to convince my boss of that. We are likely trading this one out next season, so he tends to balk at that.
/ If you have Toolcat questions, ask them here... #308
Thanks, that's were I'm heading.
DEWFPO
/ If you have Toolcat questions, ask them here... #309
Got a 2004 Toolcat 5600 with 1100 hours, picked it up recently. Everything working fine for about a week, yesterday it didn't want to go in reverse. Will back up with effort, moves ok in forward, some resistance. As soon as you let off the gas pedal, it comes to a quick stop. Thinking brakes are locked up. Not sure where to start. Open to suggestions. Did check hydraulic level and fluid condition. Looks okay.
/ If you have Toolcat questions, ask them here... #310
Any warning codes when this happens?
2020 FREIGHTLINER CASCADIA 126 6X4 T/A SLEEPER TRUCK TRACTOR (A59906)
2020 FREIGHTLINER...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
Bestway Ag 50 Gallon 12V UTV Skid Sprayer (A60463)
Bestway Ag 50...
CFG Industrial MX15RX (A60463)
CFG Industrial...
2016 DRAGON SAND CONVEYOR (A58214)
2016 DRAGON SAND...
2024 Linx UT708318T (A60463)
2024 Linx...
