Your thoughts on my basement plans
/ Your thoughts on my basement plans #141
Instead of hiring a pumper, I was thinking that I could have two cement trucks there at the same time, but at either corner. I didn't think about having them go slow and doing it in lifts. That makes sense, so I will probably have to pay a little extra to keep them on sight longer then they want to be just to keep them going slowly.
So it goes without saying.... that's why I'm saying it :laughing:, you'll have to move your excavated dirt well away from your hole to allow for the cement trucks to maneuver.
If your walls are 16' x 8' x 10" thick, and there's 4 walls, that's what? about 16 yards of concrete. You'll need two trucks anyway, as they only hold about 10 and are sometimes limited to less because of weight and road restrictions, so its a good idea to find that out well in advance.
/ Your thoughts on my basement plans #142
Eddie,
Have you put the upside and downsides of your plan to paper? Pros vs Cons of your method vs traditional? When I start thinking about your plan the cons far outweigh any pros or benefits. Just something to ponder. Also a couple of other thoughts on your liner. Do you have any trees around the house or plan to have any? I'm just curious about root penetration and whether or not this would be a concern. They will buckle sidewalks and smash drain pipe over time so not sure about the effects on your liner. Also wondering about rodents, moles, etc. Also how about condensation between the liner and concrete that is above grade. I'm just thinking about a hot black liner next to your cool foundation. Not sure there would be enough condensation to worry about but just another thing that comes to mind. You might also think about resale value. I know in my area if I looked at a home for sale with a basement done this way I would run fast. It sounds like you have convinced yourself that your way is better so I hope it all goes as planned now and in the long run. To me it looks like a slow moving disaster, or a fast one if the forms give during the pour. I really hope I am wrong.
/ Your thoughts on my basement plans #143
Eddie
How easy will it be to move concrete trucks around your site? To minimize unbalanced loading of forms you will want to bring the concrete up in the walls as equal as possible, pour concrete in circle going around the perimeter.
Is there a good builder supply store in Tyler, they will sell form oil which does not have a strong odor.
My only experience with Tyler is that my daughter played against the women's basketball team from Uof T Tyler, they were a good team.
I would not worry about resale value, if all goes right the buyer would not know the foundation is not traditional unless you tell them. If things go go bad there will be more important things to be concerned about.
Curly Dave
Everything that I have read or been taught in seminars is that the vibrator needs to penetrate the previous layer of concrete to properly consolidate the two layers. Most people when operating concrete vibrator will move it too quickly. Slow is good
I may have read it wrong but one of eddies post talks about 12" thick roof that I assumed was concrete.
You are correct that rebar spacing is critical in developing the strength of the reinforced concrete
/ Your thoughts on my basement plans #144
...Everything that I have read or been taught in seminars is that the vibrator needs to penetrate the previous layer of concrete to properly consolidate the two layers. Most people when operating concrete vibrator will move it too quickly. Slow is good...
I have always taken that advice to mean that it has to enter the top of the previous layer, not that it has to go completely through the previous layer.
The previous layer has already been consolidated, all that has to be accomplished is to get the two layers to properly knit together.
/ Your thoughts on my basement plans #145
Curly Dave
Vibration will need to consolidate the two layers into one homogeneous layer. To do that you need to penetrate at least several inches into previous layer
/ Your thoughts on my basement plans #146
:laughing: Curly Dave had a lot of intricate detailed advice on how this unusual setup MIGHT work out....
Eddie...is it still looking better than doing it the conventional (and, frankly, easy) way? I think your plan is making it far harder and less likely to succeed, but then I guess you know what I think by now. I'll stay out from here unless something really scary comes up that I think is going to hurt someone...
/ Your thoughts on my basement plans #147
I woke up this morning with the realization that I really don't want a basement, and I was overthinking this whole thing, making it a lot more complicated then I needed to. My reasoning for the basement was protection from tornadoes. Since I'm digging a hole in the ground, I might as well make it as big as the room that is going to be above it. There is no reason for a tornado shelter to be 16x16 feet. Once I got to thinking of how big it needed to be, and that while we where in it, we where going to be wide away and not doing anything until the threat had passed, I got to thinking that I could have everything i wanted by just building an above ground shelter in the corner of my garage. This now removes a huge weight off of my shoulders and allows me to move forward with what I really want to do, build my great room!!!
Thank you, I really do appreciate all the great advice and humoring me while trying to figure out how to build something that I now realize, I no longer want. If I would have just listened to my own words when I said that I never plan on going down there once it's built, I would have realized that I really don't have any need or desire to have a basement. As for storing stuff, I am already in the process of creating a canning/processing room that is 12x24 that will hold everything we plan to can or pickle.
/ Your thoughts on my basement plans #150
Sounds now like a logical and economical decision based on your usage plan. Now let's start seeing the progress pics! What exciting feature do you have up your sleeve (remembering the gazebo roof!) for your great room?
/ Your thoughts on my basement plans #151
I think that is a great decision. Sure, it is possible, but it is not easy and there are much better ways to do it.
/ Your thoughts on my basement plans #152
Eddie, my complete house HVAC supply ducts are PVC under slab. Return in attic. That's how it's cooled and heated for less with a 2.5 ton unit that's 32 years old and that's why my basement is inset 5' on one side of the house and 3' on the opposite side. That's how ducts and water supply gets to that other end of the house.
Interesting. In my house, I installed galvanized rectangular ducts under the slab, before the pour. I used
conventional ducts, wrapped them in 1" rigid EPS foamboard, then covered them in 1/2" concrete backer-board.
The backer-boards were to keep the ducts from getting crushed by the slab jockeys during the pour. I
considered round PVC pipes, but to get the same volume, I would have to dig deeper, and insulating them would
be harder.
Before I did this, I asked some HVAC contractors how they would install heating ducts under a slab. I got
only blank looks.
/ Your thoughts on my basement plans #153
Kind of like post #14. Ours is 8'OD but just enough room for some bunk beds, a chair and some snacks.
be harder.
only blank looks.
Just curious why would you want to insulate a duct that is buried in the ground under the slab? I'm thinking that Schedule 40 PVC will be strong enough to support any weight that is over it during the pour, and once the concrete cures, it wont matter. I'm still thinking on what size to get. The sticker shock of the pipe will hurt, but it's better then using a window unit.
/ Your thoughts on my basement plans #155
Dirt is a good conductor. The only thing better is water.... Even a 1/2" of rigid foam will act as a break to keep the heat or cool in the duct and not be heating or cooling the great outdoors. Condensation may be a second issue you want to avoid.
/ Your thoughts on my basement plans #156
Eddie I'm looking forward to your great room build. Can't wait to see what you come up with. Maybe I missed it but do you have a timeline on this yet?
/ Your thoughts on my basement plans #157
WESTCLIFF has got it right. I would lose a lot of heat into the ground if I did not insulate.
Cooling would not be a great issue, however.
PVC pipes are plenty strong, but insulating them is not easy, esp if you want crush-proof
insulation. Also note that you would have to go deeper for equivalent volume to conventional
ducts.
Note that 14"x3" galvanized steel ducts, the kind you use for stud cavities, are quire inexpensive, too.
They have much greater cross-sectional area than a 6" pipe.
/ Your thoughts on my basement plans #158
ducts.
We are doing a total remodel on the exterior that will include a new back porch and adding on the canning/processing room. I am in the early stages of converting the 10x10 shop door into a 16x7 standard garage roll up door with an opener. Down the road I will build a much bigger, butter workshop and my current attached workshop will become a place where Karen can park every night and we can unload her car out of the weather when she buys groceries. I am working on plans for the above ground storm shelter that will go into the corner of the garage, out of the way, but easy to get to in case we have to.
Once all that gets done to a certain level, I will start on the dirt work and get the pad poured for the new great room. If all goes well, that should happen this spring once the rains stop and the soil is firm enough to get cement trucks into position.
On the AC duct under the slab, there will only be cold air going through it. 100 % of our heat is from our wood stove. So no hot air will ever go through the duct under the house. I would prefer a solid pipe without any insulation around it for strength. I think insulation would leave voids under there.
/ Your thoughts on my basement plans #160
Eddie check into your annual ground temps for the depth you would install the pipe. What you want to avoid is any condensation forming in the pipe that might sit there for extended periods and allow mold to get going which will then be spread into your room when you turn it back on in late spring
Google "earth tubes" to get more info on what folks use and potential issues and how to avoid them.
