Closing valve in hydraulic curcuit, JD4410, why?
   / Closing valve in hydraulic curcuit, JD4410, why? #1
JohnDeere4410
Norway
JD4410
Hi!
Posted this in wrong place (?), try again :)
In the back of my JD4100, there are a hydraulic line with a suction filter originally. (In the manual). But someone who owned the tractor earlier has replaced it with a electric 2-way valve. When i activate the valve by a not original mounted switch, i can hear the engine is working harder, due to the closed hydraulic curcuit. When i use the hydraulic, as the lifting arms, the engine is working easyer again.
So what is the purpose of the valve? I would like to remove it, as my hydraulic sylinder runs into it when lifting equipment all the way up.
   / Closing valve in hydraulic curcuit, JD4410, why? #2
Is there a third SCV valve that controls the top arm hyd. cylinder?
If so, that valve may have been placed there to divert the third SCV valve to operate a different hyd. cylinder, such as for a grapple on the FEL (or some other use for another hyd. cylinder).
Thanks for the reply :)
There is an own leveler that controls the top arm hyd sylinder. Connected to the two outlets in the right of the picture.
The strange thing is that the valve on the picture is closing the curcuit, instead of diverting it to somewhere else...? Or do i misunderstand this completely?
By the way, i am thinking of bying an electric diverter 6-2 valve to have an extra cylinder moving the angle of a back-mounted snow blade. I will then have a snow-blower in front, and blade(what is it called??:)) in the back.
   / Closing valve in hydraulic curcuit, JD4410, why? #4
Maybe previous owner removed some hyd. lines and re-hooked the remaining ones wrong. Do not really know.
We call the blade in the back.. a back blade. ;)
We'll be interested in how you further track down the problem.
Did the previous owner mix up open and closed Center Equipment ?
Last owner did not know what the valve was, so i really dont know....
Do the 4410 have open center?
And yes, ill keep you updated :)
I am also trying to get a block heater with 230v. All i find is with 110V
   / Closing valve in hydraulic curcuit, JD4410, why? #7
There are no other ports on that valve body? If no then I can see no reason for it whatsoever. In fact if left closed damage to the pump or overheating the fluid can easily result.
Your 4410 is indeed Open Center.
That line is what's called the "power beyond" line, I would restore it and eliminate that valve if it was my machine.
Thanks again for reply.
There are 2 ports that are blinded. Looks like they have never been in use...
   / Closing valve in hydraulic curcuit, JD4410, why? #9
It is possible that two hoses could be hooked to those ports, and then to a cylinder to control it. Any part numbers on the valve?
   / Closing valve in hydraulic curcuit, JD4410, why? #10
There is a free parts book on the JD web site .
It does appear that the hydraulic system is being dead headed with this additional valve. As previously stated something wll eventually become over heated and ruined in the current configuration .
Usually Deere lists 240V block and transmission heaters .
Philips and Tembro list every size , shape, voltage and wattage of both oil and water heaters .
GRILL GUARD & POOL LADDER (A58374)
GRILL GUARD & POOL...
2022 Ford F-150 XL Pickup Truck, VIN: 1FTFX1E50NKE58889, Extended Cab, 4 x 4, 5.0 L V8 Gas Engine, (A59076)
2022 Ford F-150 XL...
2023 Kubota SVL97-2 Compact Track Loader (A56435)
2023 Kubota...
500BBL FRAC TANK (A58214)
500BBL FRAC TANK...
LOT: (48) 2.5 Gallons of Star Fire Diesel Exhaust Fluid (A59076)
LOT: (48) 2.5...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
