Put a Back Blade on the FEL?
/ Put a Back Blade on the FEL? #1
Msamt
Gold Member
Enfield, NH
Kioti Dk45SE
Here's a question, has anyone fabbed up a way to put a BB on a SSQA fel?
/ Put a Back Blade on the FEL? #2
Yes build or buy a ssqa to 3 pt adapter. I built one and use it for all types of stuff.
Exactly! So just a SSQA blank, some tabs with holes, and some pins (if I want to keep it simple)?
/ Put a Back Blade on the FEL? #4
Not a back blade, but a box blade, pictures to give you design ideas for an adapter.
I bought a SSQA to 3 point adapter with extra rollback angle built in.
/ Put a Back Blade on the FEL? #5
/ Put a Back Blade on the FEL? #6
Years ago when I bought my tractor I bought a Land Pride 6 foot rear blade for clearing snow. But I quickly got tired of craning my neck looking back. So I cut the head off the attachment and welded a "socket" onto a cross member that attached to my loader arms as you can see in the picture. On the 3 point section I welded another socket for when I really wanted to use it as a back blade.
Great ideas and exactly what I'm looking to do. thanks!
/ Put a Back Blade on the FEL? #9
The biggest problem with that set-up is no trip springs or anyway to give if (when) you hit a solid object.
/ Put a Back Blade on the FEL? #10
There aren’t any on the bucket either. How fast do you think he’ll be going?
Yeah, small driveway and limited plowing area, so i'll be going really slow.
Thanks all for the ideas, pics and direction, ordered the titan adapter from amazon, pics when it gets here.
/ Put a Back Blade on the FEL? #13
I welded a 3pt Quick Hitch to a SSQA plate & love it. Handy for moving stuff around. I welded up an adapter for a cheap truck plow that fits the Quick hitch hooks & mount it that way. Mounting a 3pt blade of any sort there will work, but will be less than ideal. The truck plow has some side to side tilt built in, which you need.
/ Put a Back Blade on the FEL? #14
Used an adapter plate and mounted an old backblade onto it for snowplowing duties. As others mentioned, there is no built-in give to this arrangement, so if you hit something, you'll do one of 3 things: Come to a dead stop in a hurry, break whatever you hit, or break or bend the weakest point on your FEL/blade apparatus. Or any combination of those 3. Know your driveway and go slow.
The steel blade edge is hard on the blacktop sealer, so I took a piece of 6'x6' horse stall mat, cut off a 4" strip, and bolted that onto the blade. Scrapes the driveway clean and doesn't scrape off the blacktop sealer.
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
(1) 235/80R16 TIRE W/ (8) LUG WHEEL (A64280)
(1) 235/80R16 TIRE...
3Pt 2R Planter (A66408)
3Pt 2R Planter...
HD Bale Ring (A66408)
2016 CATERPILLAR CT660 SBA 6X4 DUMP TRUCK (A63276)
2016 CATERPILLAR...
