Good morning!!!!
   / Good morning!!!! #39,371
if Hollywood is also involved maybe a break in her day job is in order.
Kinda depends on her day job, Don. If she's young and working an entry level position, then taking a chance at grabbing the gold ring is probably a good idea and she's got plenty of time to recover if it doesn't work out. If it's something she's studied or trained years to qualify for, then not so much.
   / Good morning!!!! #39,372
Retraced everywhere I had been that morning. Still nothing. Have to assume they are gone for good - unless someone sees a sheep wearing spectacles.
How DOES one find one's glasses when they're needed to see? Hope you have a spare pair to wear until the new ones are finished. Likely that'll be just about the time you find the old ones while you're looking for something else. At least that's the way it works around here! :duh:
   / Good morning!!!! #39,373
Today's opening act was certainly worthy of a snapshot...
   / Good morning!!!! #39,374
Good Morning! 39F @ 3:45AM. Abundant sunshine. High 61F. Winds N at 5 to 10 mph.
Two evenings ago the alarm system started to complain about something by beeping very, very loudly at about 10PM. At that point I was able to get it to tell me it was a failed smoke sensor (yes, it talks), but since the sensor is located 15' up a wall, there wasn't much I could do about it at the time except push the reset button and go back to sleep. That kept it happy until 2AM when the same five beeps once again reminded me to fix the smoke sensor, just in case I'd forgotten in my dreams. Oh, and stopping the racket meant another trek across the house to the alarm panel to push the reset button again. At 6AM I got another reminder, but of course since I'd slept so well the night before I didn't mind jumping out of bed to push the reset button yet again, and jump into my work clothes to drag the extension ladder inside to climb the wall. NOT!!! But I did retrieve the smoke detector later in the morning, installing fresh batteries, and clearing the error on the alarm panel. No more beeps, so I started back in on paperwork until the garage warmed up a bit.
With the heads done it was time to figure out if they were the same size with respect to interior volume. I'm trying to build a very smooth engine this time, and one factor is combustion chamber volume, which the experts say should be the same on each side. To measure this one fills the chamber with liquid and measures how much it takes. Since there are two holes for spark plugs, and I had no wish to ruin a pair of them with paint thinner (apparently the liquid of choice), I turned up a pair of plugs from aluminum and installed an o-ring on each to make a seal when they were screwed into the spark plug holes. I even found a scrap piece of clear plexiglass to cover the opening where the piston comes in, and got a hole drilled into the center of it without cracking it into a million pieces. A smear of light grease around the edges provided a good seal to the head, and I was all set to start measuring. I used a big horse syringe to load paint thinner into a graduated cylinder, stopping at precisely 100cc. Emptied the syringe, then pulled out precisely 35cc and loaded it through the hole in the plex into the combustion chamber. Filled the cylinder back up to 100cc and loaded up the cylinder with another 35cc, and now the thinner had trapped a bunch of bubbles under the plexiglass. One more 35cc dose but the bubbles wouldn't clear, so enough thinner was sucked out to drop the liquid away from the 'glass to clear them, and then very carefully and slowly the level was brought back up. The head wasn't exactly level, so the big bubble that formed was located off to the side of the filler hole and I had to tip the head to keep the bubble centered as I pushed the liquid out of the syringe. It was a real test of hand eye coordination, especially as the paint thinner caused the rubber seal in the syringe to swell making it difficult to push the plunger. But eventually I got all the bubbles out and the chamber completely filled to the bottom of the hole. I returned the leftover thinner to the graduated cylinder and found it had taken an additional 13cc to fill the chamber, for a total of 83cc. Not bad for a first try, but the scientific method calls for a statistically significant sample to evaluate experimental error. So all the thinner was sucked back out of the head and everything cleaned and dried with compressed air so the whole process could be repeated. After three tries all came up with 83cc plus or minus half a cc and it was time to move on to the other head. Same result there, and by then my back and shoulders were sore from hunching over the bench, it was getting cold in the garage, and it was time for dinner. Today I'll do a little math to figure out how much difference in compression ratio a half cc makes; then I'll know if my method is precise enough or I have to sharpen my pencil.
Inside a quick pizza and salad was good enough for dinner, but now a new chirping sound could be heard during pauses in the evening news. When it was over I muted the sound and listened and yes, something else was complaining, and it wasn't any of God's creatures. A new electronic devil had come to call. Not nearly as loud as the last one, and only a single chirp that repeated seemingly at random. It led me quite a chase through the hall, into the great room, then into the kitchen, laundry room, and even into the garage. At each place the sound seemed to be coming from somewhere close by, but not quite there. Oh the joys of an open floor plan and lots of hard surfaces perfect for making echos. So after half an hour of fruitless searching, I screened the latest episode of "Somebody's Gotta Do It" making plans at some future point to spend a night in a tree house in Oregon and ride both the zip line and Tarzan swing while I'm there. Tried to get through "60 Minutes" but found myself nodding off during the last segment. The chirps hadn't stopped, but they weren't loud enough to keep me awake and I went to bed.
Which brings us to why I'm updating the Good Morning thread at 3:45AM. At about 10:30PM those five obnoxiously loud beeps rang out again, and sure enough the smoke detector was once again demanding attention. :banghead: No choice but to push the reset button and head back to bed for another four or so hours of sleep before yet another reminder that I'd be back up on the ladder today. But by then I couldn't get back to sleep, so I thought I'd warn you guys to NEVER let anyone talk you into letting a GE Simon alarm system into your life. Having accomplished that, I think I'll try to get some more sleep. But first I'd better go push the reset button again first...
   / Good morning!!!! #39,375
Wngsprd, nice sunrise! It's hard to get the exposure right when the sun is involved even on auto but that is a perfect pic.
RNG, she is in position "A" so not much to loose that she cannot re-gain later.
Good morning! No wind, high clouds, 52˚ - a cool front came in slowly last night and only getting to 68˚ (20˚ cooler than yesterday).
With things breaking and being the constant maintenance man and then chores for mom and dad this retirement JOB is turning into only one day off a week, if I'm lucky. There seems to be no benefit in retiring.
Yesterday was a wash when I had to take my dad to his Dr. appointment.
All effort today will be to fix the club car. I went to town yesterday to price one similar (hi-rise, big tires, bedded) they are about $4,900 so I have a lot to work with. The owner of the cart shop had worked with one of my cousins in the oil field so he gave me a bunch of advice on how to fix mine and he said he would attempt to fix it if I failed but he really prefers gas golf carts.
   / Good morning!!!! #39,377
Eric, I got bushwhacked in the woods and lost my glasses for a week. I, like you, walked around for a while wondering why things were blurry. I did not find them till I got out my metal detector and searched the area.
   / Good morning!!!! #39,378
52 this morning and headed to 60 today. Cool and windy.
Need to move the equipment I couldn't do this weekend. Then a meet and eat in town with the poultry company. Biosecurity training. Could get interesting with a full belly. Then hopefully start washing fans.
Took boy to allergist yesterday. His individual allergy test scores came back as low as they could. His total score was 51. Anything under 100 is normal. So allergist said to call if we needed anything but no reason for her to see him anymore. She then talked to us about the ENT visit and the tubes, speaking highly of the doctor we chose.
Eric. Hopefully you find your glasses. I wear contacts and that has helped with those problems. Now if my contact gets off my eye it hurts and eye waters so I know instantly. Although I knew instantly with my glasses. I can't read a book over 6-8 inches from my nose without glasses or contacts. Good luck.
   / Good morning!!!! #39,379
Yes, it was photo worthy this am. i thought, red in the morning.....
Weather is turning, rain now.
   / Good morning!!!! #39,380
Good morning all. 45F going to 67F clear and much less wind than yesterday! No rain here yesterday, although south of Dallas got some. Mowing, boat seat and dog sitting on agenda today. Rain in the forecast Sundat through Tuesday so need to work on outdoor projects.
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A48081)
2015 Ford F-550...
John Deere 350 PTO Manure Spreader (A52128)
John Deere 350 PTO...
Walking Floor Trailer 43ft (A50322)
Walking Floor...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A52128)
Kubota BX2680...
2015 F-550 Bucket Truck. (A52128)
2015 F-550 Bucket...
