Homeowner Grade Stump Grinder
/ Homeowner Grade Stump Grinder #1
Spencer
Western Michigan
NH TC33D w/R4 Tires, Rear Remote, Hydraulic Toplink, 2 Auxiliary Work Lights, 7308 Loader w/Kasco Uni-Hitch (Quick Tach)
I've dug out dozens of stumps with my tractor, but I'm getting to the point where some of the stumps I need to take out are near underground utilities and others are in areas that I don't care if the base of the stump stays below ground.
So, I've been thinking harder and harder about getting a stump grinder. I've been watching Craigslist for a couple of years and haven't seen any used commercial grade units come up for sale locally. I have seen a few used DR Power stump grinders, but they've been the lower-end models and the sellers have been asking close to retail, so I haven't jumped on any of them. Someone must be buying them though, as the listings don't seem to stay up very long.
I am considering a new unit from DR Power. Their most powerful unit, the Pro-XL, has been on sale for a while now for $2,399. I realize their stuff is fairy light-duty, so the Pro-XL is their only unit I would consider. With free shipping this price looks very attractive.
The next step up from the DR Power unit in a name brand that I recognize is the SG13 from Husqvarna for $4,099. I realize this is a beefier machine and it would maintain a much better resale value, but I generally hang on to my equipment, so resale is really not a factor. While I'm sure it is a much better machine and probably worth the 40% increase in price over the DR unit, I'm not sure I really need much more than the DR.
Other than welcoming your input on these two units, I'd appreciate any advice on other homeowner grade stump grinders that I should be considering.
Thanks, Spence
/ Homeowner Grade Stump Grinder #4
It looks like those are over $6K, which is more than I care to spend on this.
I've seen them closer to $4K, but have no idea of their quality at that price. True, they are not cheap.
From my experience grinding stumps - a bunch - bigger, beefier, is almost always better. I want the machine doing the work - not me.
/ Homeowner Grade Stump Grinder #5
Don’t want to spend for a grinder ? Get a hydraulic auger with about a 30 inch auger , sharpen it and drill through the stump centre . Works pretty good .
/ Homeowner Grade Stump Grinder #6
Maybe rent one from a tool company, just a thought.
/ Homeowner Grade Stump Grinder #7
We rented a commercial self propelled one for about $125 for a weekend (Friday afternoon until Monday morning). Ground so many stumps that the teeth were dull when I returned it. They said don't worry about the Hr's, the meter don't work so use it all you want. Cleaned up the property real well that weekend - well worth the rental rate.
/ Homeowner Grade Stump Grinder #8
I dig around the stumps a few inches down with a shovel, then wash them off and cut them off below ground level with a chainsaw...
You may have to sharpen the chain when you are done, but that's not a big deal at all...
SR
/ Homeowner Grade Stump Grinder #9
/ Homeowner Grade Stump Grinder #10
Have you priced someone doing the grinding for you? We had a lot to grind when clearing our home site and no way buying would better value than hiring them ground. But that would vary depending o the local market.
/ Homeowner Grade Stump Grinder #11
I would like to see a video of this. Can't find one on the net.
/ Homeowner Grade Stump Grinder #13
Next time I have my auger on the 312b , I will make a video.
/ Homeowner Grade Stump Grinder #14
That giant forstner bit in the second vid is interesting. Looks like it would work on any driver that runs Pengo style augers.
/ Homeowner Grade Stump Grinder #15
I purchased the Cabelas tsg 50 for 3400. It is made by Woods. My local woods dealer wanted 4800 for the same unit. It works awesome behind my Kioti dk 50.
/ Homeowner Grade Stump Grinder #16
Sweet! Now we need some action photos (or video).
Congrats, that is a nice attachment!
/ Homeowner Grade Stump Grinder #17
Here is a clip of mine in action
http://youtu.be/CJ91ruuvgnQ
As you can see, I could use more HP, even though my tractor is on the upper range of power for this unit (15-35Hp).
It does a nice job for me and I have removed over 100 stumps since my purchase three or four years ago
/ Homeowner Grade Stump Grinder #18
Check out home depot rental. They sometimes sale their rentals at a discounted price. Here's one in Kalamazoo for ~$1k.
http://www6.homedepot.com/used-tools/index.html
The Bluebird is comparable to the SG-13. I purchased a Toro SG-13 from my local HD, but still have not had a chance to use it. Mine looked in very good shape with 59 hours on the meter.
