Mini split A/C Heat Pump systems
   / Mini split A/C Heat Pump systems #71
pulling a vacuum and sustaining a vacuum serve different purposes... however, the process of both yields important information about the conditions within your system. Also, a high pressure test is just as importation as a low pressure test... You can't exert (test) the forces of "normal" operating conditions on the piping network by only performing a low pressure test.
Manufactures will explicitly specify the micron level to which they require to achieve their warranty requirements.
If I were to pull a vacuum . I would hope I could sustain it..;)....If I can't.. Well......:eek:
   / Mini split A/C Heat Pump systems #72
I have a Mini Split and have been very pleased with it.
One note of caution, there are no "do overs" with Mini spilts. They come filled from the factory and should not (i.e. voids your warranty) be recharged in the field.
And how would the factory ever know this ?
   / Mini split A/C Heat Pump systems #73
In certain circumstances, it's possible to pull a vacuum in an open loop (leaking/unsealed) environment... As long as the pump is running, a vacuum level could be achieved and sustained. However, when the pump is shut off the vacuum may not necessarily persist. That's what I was intending to clarify with my previous comment.., and that's why there are "standing time" evaluation measures when performing hi/low pressure testing of refrigerant piping networks.
Also, I've worked with and been around "vacuums" that weigh hundreds, if not thousands, of pounds... so there are some out there that you might not actually be able to "pull" ;)
2016 John Deere 35G Mini Excavator (A49461)
2016 John Deere...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A49461)
2009 Trail King...
2007 MD-8 TRIPLEX PUMP POWERED BY 1050HP MTU ENGINE (A50854)
2007 MD-8 TRIPLEX...
2017 Ford F550 4x4 Bucket Truck - 45FT Terex TL40 Boom, Powerstroke Diesel, Utility Bed, 54K Miles (A51039)
2017 Ford F550 4x4...
Miller and Smith PNR-1000 Pull-Behind Proof Roller Trailer (A49461)
Miller and Smith...
2021 ALLMAND BROS, INC. NIGHT LITE LIGHT TOWER (A50854)
2021 ALLMAND BROS...
