GPS Tracker?
/ GPS Tracker?
This is a 36w LED bought on ebay for $20. I connected to the work light circuit.
You use just the one light? It looks like it should produce plenty of light. Also, did the bracket come with it? Or did you fab that up?
/ GPS Tracker? #42
Thank you all. Got a little seat time today. Float works as described. Not sure what I'll ever use for but glad to know how it works.
Sent from my SAMSUNG-SM-G890A using TractorByNet
/ GPS Tracker?
/ GPS Tracker? #44
Nice. I like the low profile. Have a link to the switch?
/ GPS Tracker?
/ GPS Tracker?
I am regretting the 60" blade I let the dealer talk me into. I would much rather had a 72". But I'll try and get used to it.
/ GPS Tracker? #47
I just drilled a hole I'm my dash & put in a standard on-off switch with a boot on it.
/ GPS Tracker?
I have a problem with cutting or drilling into a new machine. Im weird like that. I will eventually get over it though.
/ GPS Tracker? #49
Same here. Needs a couple dents or scratches for me to get over it.
/ GPS Tracker?
Well the light bar came in today. Was playing with what it may look like. I am thinking of putting it on the rops instead. Only because I don't want to drill into the grill guard. There is a little bit of bucket glare. But nothing like from the factory head lights.
LED's only
With headlight also.
/ GPS Tracker? #51
I put my light bar on the rops, used a couple pieces of angle and a couple exhaust clamps that I slid rubber hose over to make a bracket and clamp it down. Mostly because of what I had laying around the garage and scrap pile
/ GPS Tracker?
Do you have any problems when you look back? I am worried about glare when looking back. Had that problem with my old Kioti that I have lights mounted on the rops. And the bar was higher then that of the Kubota.
/ GPS Tracker? #53
Not with my setup. Not sure how that would be likely either, unless you were plowing reflective snow in the dark. The lights up high pointed down & behind don't have anything but the ground to reflect off of. Maybe a shiny implement?
/ GPS Tracker? #54
I don't have a problem with glare. I would guess maybe just aim the light up/out a little more
/ GPS Tracker?
It was direct light from the lights themselves that was blinding. Maybe I had them pointing down to far. When I get a chance I'm going to pull it into the big shop and play with the placement before I do anything to drastic.
/ GPS Tracker?
Looks good.
The biggest problem I have is where I store my tractor I only have a 7' door. So I can't keep my rops up all the time.
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Peterbilt 567...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2022 EZ-GO ELITE...
2018 International Durastar 4300 Asphalt Pot Hole Patcher Truck (A64556)
2018 International...
2018 CATERPILLAR 305E2 CR EXCAVATOR (A65053)
2018 CATERPILLAR...
