leonz
Super Member
Simply not true at all. The gas line right-of-way guys prove that incorrect every single day. People would be shocked at what they mow around here, and would assume they're using some sort of tracked machine. But all they have are 4wd tractors with roll cages. Granted, they have bigger stones than me. But it's possible.
Besides, 50% slope isn't all that bad. If I couldn't bushhog a slope like that, most of the farm would be overgrown.
I think you need to measure your slope angles, you can buy a Suunto Clinometer
from Ben Meadows pretty reasonably.
What you are referring to is a log skidder with forestry mower and
that is an entirely different animal my friend. Most have planetary axles and
huge tractive ability
They have a much lower center of gravity, articulate in the center and have a
wider foot print than your tractor and in most cases all four tires have liquid ballast
in them because they are climbing up and down rights of way with four speed
full reversing automatic transmissons.
Spend the money on a clinometer and then compare your slopes to the recommended sidehill
mowing angles of 15 degrees and go from there.
ITS YOUR MONEY AND YOUR LIFE you should look at the Nebraska tractor tests to see what
the allowed slope angles are for your mule.
