Trans Fluid
/ Trans Fluid #1
whatever1
Earth
Has anyone heard that Kubota has increased the time for a transmission oil change to 400 hours from 300 ?
/ Trans Fluid #2
This has been hotly debated item on here, with posters saying Kubota has told them the 300 hour interval still holds. I split the difference and changed mine at 350 hours.
Will
/ Trans Fluid
I was told by a dealer that Kubota upped it to 400
Will
/ Trans Fluid #4
I guess that would depend on the model tractor you are referring to? All Kubota tractors don't have the same service interval time for changing the transmission fluid. I have 5 Kubota tractors with service intervals ranging from 300, 400 and 600 hours. Best way to find out would be to contact your dealer or Kubota.
/ Trans Fluid
BX-24 Kubota change from 300 to 400
/ Trans Fluid #6
Is there a service bulletin for this?
/ Trans Fluid #8
Unless you are planning to get rid of the tractor, why not just follow whatever is in the owner's manual? You will be changing it anyway, so follow the book. That way, if any warranty issues crop up, you are good.
/ Trans Fluid #9
I thought you were supposed to use a shop vac on the filler hole to keep the old dirty oil in and just change filters??
Hahahaha.
/ Trans Fluid #10
Here's that special Kubota oil change tool that came with my tractor.
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
2023 New Holland C327 Compact Track Loader Skid Steer (A61572)
2023 New Holland...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
3 Brake Drums (A62613)
2019 Mack Granite Tri-Axle Dump w/ Lift Gate 006043 (A62613)
2019 Mack Granite...
