Aftermarket Mulcher Teeth
/ Aftermarket Mulcher Teeth #1
fishfactor
Gold Member
Monroe, NC
(2) 2014 CAT 299DXHP / FECON
If you guys remember, I posted a while back, maybe 18 months or so, about some aftermarket teeth we were trying on our Bobcat Branded (Fecon Made) mulcher. After getting sick and tired of paying crazy prices at Bobcat, we approached a manufacturer about this and had him build us a tooth. We were testing prototypes, and after a few adjustments and improvements, we are happy. What we ended up with is an adapter/cartridge combo that can run several types of carbide tipped teeth. You bolt the adapter on using your factory bolts, then the tooth locks in a dove tail, and is secured with another bolt. These teeth are way, way cheaper than factory teeth. I know he has several different versions to fit different machines, but I know for sure he has them for the fecon v back, and the bobcat head that uses 2 hex cap bolts to hold the tooth on. Just be sure to check the spacing on your bolts, as the newer heads I have seen have a different spacing than ours.
The reps contact info is below:
Jonas Eldred
901- five zero 3 - 0250
jeldred at opteaminc dot net
They look blocky, but that is actually by design to provide more protection to the base. Some of our bases were worn from running broken and worn out teeth, so he did these a little larger than the base. I call these planer carbides. He can also do the standard splitter carbides.
/ Aftermarket Mulcher Teeth #4
That’s awesome. What’s the price difference between the OEM and your new aftermarket teeth? I know a guy who runs one of those huge rock crushers, FAE I think. I believe he told me the teeth on that were like $750 each.
/ Aftermarket Mulcher Teeth #5
That痴 awesome. What痴 the price difference between the OEM and your new aftermarket teeth? I know a guy who runs one of those huge rock crushers, FAE I think. I believe he told me the teeth on that were like $750 each.
Hey Tejas. I see you are near Hondo.. I'm in Pipe Creek.
I had an FAE rock crusher on demo. The teeth were between $85-$100. They are similar to mulcher teeth but blunt. I'm not sure what type of rock crusher your friend has but $750/tooth would make it very expensive to run. I had good luck with the rock crusher I demoed and the teeth held up well until I hit a piece of rebar in concrete and even at that, it still only chipped the carbide.
/ Aftermarket Mulcher Teeth #6
we have these mulcher attachment carbide teeth including bobcat forestry cutter teeth and more. message me for pricing and availability or visit ConstructionPartsLLC.com Thanks!
/ Aftermarket Mulcher Teeth #7
How much for the cutter teeth? Bh-46bp-2 need of them how much are they each?
/ Aftermarket Mulcher Teeth #9
We have a full line of Teeth for all of your Forestry Mulchers. All of our teeth are 100% CNC machined from alloy tool steel and exceed the design and tool life of the OEM teeth. If we do not have your teeth in stock, we will manufacture and stock them for you. Our website will be up and running again soon.
Please give us a call so that we can begin saving you money today.
Thanks,
Jonas Eldred
2016 MULTIQUIP DCA-25SS1U4F PORTABLE GENERATOR (A63276)
2016 MULTIQUIP...
1948 Willys CJ2A Jeep (A61166)
1948 Willys CJ2A...
Mini Skid Steer (A60352)
Mini Skid Steer...
*INOP* ALL TERRAIN DUCK HUNTING BUGGY (A62130)
*INOP* ALL TERRAIN...
18' Utility Trailer (A64047)
18' Utility...
UNUSED JCT 2 PRONG BALE SPEAR (A62131)
UNUSED JCT 2 PRONG...
