mid mower blades
/ mid mower blades #1
BlackOps
northern middle tn
Mahindra Max 25
serious question - the mod mower blades - how does one get access to them to sharpen them without having the dealer do it?
That unit is so freaking heavy - it seems impossible to tip up and then stabilize with one person. do not need to do it yet - since i have not used them yet but i was wondering about this for a while now.
i think the unit is about 475 lbs. or some such thing.
/ mid mower blades #2
I would consider a chain hoist or come along if you had a place strong enough to hang it.
/ mid mower blades #3
Do you have the FEL? I use my FEL to lift the deck on mine.
Another option is to drive up on ramps and remove them from the bottom or sharpen them while on the deck.
/ mid mower blades #4
You can rig this to be very convenient. The icing to make it so is having a small impact wrench you can calibrate at its stall point to tighten them back up. Full power to loosen of course.
larry
/ mid mower blades
Thanks! Hmmmm.... i will have to think through this a bit more.
/ mid mower blades #6
I take my mmm on and off all the time and flip it over by hand often. I would say it is quite heavy and awkward but it is doable, especially if you have a helper. That being said, It would be easier sharpening the blades while they are still on the tractor/mower if you have a means to do so or better yet- remove the blades while up on a ramp as suggested. Its just not as easy to get the right hone on them while they are still mounted. I pull my deck off regularly to perform other task with the tractor when I need the ground clearance and prevent damage to the mower. I just try to do the deck maintenance then while its off. I bought a second set of blades now and just swap them out and sharpen them at my convenience.
/ mid mower blades #7
Definitely FEL. I have a drive over deck, use a chain to lift it with the FEL. I have a axle stands to store it vertically if I'm leaving it off. My back is very grateful.
New/Unused Electric Golf Cart (A61166)
New/Unused...
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
2017 CATERPILLAR 242D SKID STEER (A62129)
2017 CATERPILLAR...
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
2019 GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
2019 GENIE GS-1930...
2012 Chevrolet Silverado 2500 Crew Cab Pickup Truck (A61568)
2012 Chevrolet...
