Battery charging problem
/ Battery charging problem #1
malced
France
Renault N72, Kubota B1200
I have a Kubota B1200DT which I believe is a grey import since all the decals on it are in Japanese.
The charging light suddenly came on while it was running and sure enough a test proved that the battery was no longer being charged.
I have tested the alternator (permanent magnet type) and it is putting out about 18 volts. This tractor has separate rectifier and regulator units. The rectifier diodes appear to be ok so I suspect that the fault is in the regulator. The regulator is a solid state one but has no identifying marks on it. Does anyone have any information about it or know if it is possible to test this regulator without special equipment please?
/ Battery charging problem #2
Have you tested the battery?
You can test the regulator to determine its output. A multi-meter will do all the test you need.
Thank you for your replies. I have stripped back the covering on the wiring loom and found some broken wires which I reconnected. I started the engine and the charging light went out so I thought I had cured the problem. No such luck! I stopped the engine and when I turned the key to start it again the charge light flashed briefly then went out. The battery is still not being charged. Every time I switch on now the same thing happens, the charge light flashes and goes out before the engine is started and there is no charge getting to the battery. Has anyone come across this problem? Any suggestions as to what might be the cause of this fault please?
/ Battery charging problem #5
100 td said:
One of these maybe?
Amazon.com: Holdwell Voltage Regulator for Kubota Tractor B7100D B7100HST-D B7100HSTE 12V: Automotive
A dynamo puts out AC, a rectifier changes to DC, a regulator controls the output voltage in DC. Do you have 18v AC or DC? Where is this measured? What are you chasing?
An update. The alternator on my tractor is a 3 phase, and having scoured the internet I have not found any references to any other Kubota tractor having the same type of alternator or wiring arrangement to mine. It incorporates the water connection to the top of the radiator similar to the B7100 but as far as I can tell all the other permanent magnet alternators are single phase. Having no wiring schematic I have had to draw my own and it seems that the idea of the 3 phases is to increase the alternator output to compensate for when the lights are switched on. I have removed the alternator from the tractor and bench tested it. The results I got were 10v, 4v and 2v from each of the phases respectively so the alternator has definitely failed. I only tested 1 phase originally and it seems that it has gone rapidly downhill since then!
The problem I am having at the moment is with the dealer I bought my tractor from. He is situated about 400km from where I live, but as my tractor is still under guarantee for parts going local is not an option. I have been talking to him but he insists that the alternator is a dc dynamo and that it must be the regulator at fault! So the stage I am at is that he is going to send me a new regulator.
I will humour him and fit it but I know what the result will be. I get the feeling that to source a replacement alternator for me is going to be difficult and expensive and he really wants to avoid it if possible.
/ Battery charging problem #7
Can you post a picture of this "alternator/dynamo"? Also include a picture of the "separate rectifier and regulator units". This is nothing like what I've seen from Kubota. I wonder if the engine is even Kubota. :rolleyes:
/ Battery charging problem #8
How many wires entering/leaving the dynamo in total?
Colours? Possibly White, Yellow & Brown?
Possibly White/Green, Blue & White/(Black or Brown)? plus possibly 2 reds of slightly different size?
How many coils in the dynamo, 3, 6, 8 or other?
How many LARGE diodes in the main rectifier circuit?
And this is definitely a permanent magnet generator, ie., no brushes and no excitation winding?
When bench testing, ensure you spin the dynamo at 4000 rpm, measure each lead to case(ground), as well as each lead to each other, and document the results.
Having no first hand experience with these dynamos, I say the following with caution. Dynamos generally are very robust, as they are limited by the permanent magnet power, ie., they can not be over excited etc., so the windings should hold up very well and should be able to handle a short circuit. So it will be interesting to find out if the coils have failed at all.
/ Battery charging problem #9
I doubt it is a 3 phase PMG, if it has an extra leg for light wiring, it may have separate coils which it switches into circuit to supply the lamps.
EDIT: I reckon I found a similar circuit to yours, which appears to switch in extra capacity (I expect extra coils), when the light switch is turned on.
/ Battery charging problem #10
There's no extra coils in your diagram. It's set up to run the lights on AC and charge the battery with DC. It the lights aren't on, there's no flow of AC. Many older lawn tractors do the same thing using a 2 (sometimes 3) segment alternator, especially the Briggs engines. One wire from the coil will have an in-line diode to charge the battery and the other one/two wires are used strictly for lights. Others had a separate diode bridge, and depending on the load, used DC for lights.
The OP stated there were separate modules for the rectifier and regulator. Perhaps the regulator is used strictly for gauges or something. That's why I'd like to "see" what he has.
/ Battery charging problem #11
When I built the "Kenbota", I replaced the tea-cup dynamo and rectifier with a 42A Mitsubishi alternator. I was running halogen lights and some heavy draw items like 12v convertible top pumps (2) and a 12v Linear Actuator. And a BIG battery. The pumps and actuator aren't used any more (grader blade) but I kept the alternator.
/ Battery charging problem #12
As far as I can see from the attached diagram, the following is correct.
The coils are in the dynamo, they aren't shown, possibly split 4 coils for each circuit.
No. I thought that initially, but it appears that if you follow the light circuit, the lights are powered from the "T" terminal of the light switch, the "T" terminal is connected to the "B" terminal which is 12V DC direct from IGN switch/"B" terminal on regulator. Battery is charged via "B" terminal on the regulator as normal when engine running
If the lights aren't on, there's no flow of AC.
No. The AC circuit is brown wire to the "AC" terminal, and yellow wire to "AC" terminal via "S" terminal. Completed AC charging circuit whenever dynamo is spinning.
Additionally, when the light switch is activated, white wire from dynamo to "G2" terminal is connected to "S" terminal to "AC" terminal, adding some output from the dynamo to the circuit.
Yes, I said this circuit may be similar to his as it has a 3 wire dynamo and additional switching with the light switch. What he actually has, we will have to wait for the pics and info and see.
/ Battery charging problem #13
This is the ideal way to flick the little low output dynamos and get some decent output. (For me, ideally an internally regulated unit with only one wire to a charge lamp, and main output to battery, this may be one, not sure)
Hopefully you will find pictures of the alternator etc attached to this.
The alternator has 6 coils in the stator with differing windings on some of them.
I have not shown the internal links inside the light switch on the schematic, but to clarify this. The light connections are totally isolated from the alternator feeds, there is no cross connection of any kind with the ac supply. When the engine is running the alternator supply to the regulater is via the brown and the yellow wires(yellow to red on schematic) so one phase (white wire) is not in use. When the lights are switched on the brown and white wires supply the regulator and the yellow wire is isolated. In effect, only one phase is in use at any time. This makes it, to all intents and purposes a two phase system.
Given that this is just a compact tractor it seems an unneccessarily complicated set up.
/ Battery charging problem #15
I won't get a chance to go over this now for possibly a couple of days, but at a quick glance it appears that your drawing is very similar to the one I found in regards the dynamo, light switch etc. (You need to change it to English!)
Have you noticed the arcing/burning in your photo under the main switch?
/ Battery charging problem #16
Check your switch circuit diagram, the white and yellow join when the lights are switched on in the schematic, I doubt the switch is different?
Glossary of terms, french - english: Comutateur principal = Ignition switch
Voyant de charge = Charging light
Voyant d'huile = Oil pressure light
Redresseur = rectifier
Interrupteur de lumiere = lights switch
Compteur heures = hour counter
Fusible = fuse
Relais = relay
Prechauffage = preheater
As regards the 'burn marks', they are where a piece of metel has been welded into the casing to accomodate an aftermarket ignition switch.
No, they do not join. When the light switch is off the yellow and red wires make a circuit to the regulator and the white wire is isolated. When the lights are switched on the circuit is made by the white and red wires with the yellow wire now being isolated.
/ Battery charging problem #19
Looking at the diagram it appears that there is no separate regulator. It may be contained in the inbuilt rectifier. From the other switch diagram, it shows the connection of the white and yellow together when the light switch is on. This would boost the dynamo output when the lamps are on. Not certain, but this may be a fault in your switch. Do you have any pictures and circuit of the coils in the dynamo?
Can you test the "no load" output of dynamo at 4000 rpm?
/ Battery charging problem #20
When was the welding done in relation to the current problem?
2013 Atlas Copco XAS 400 JD7 Portable Air Compressor 125 PSI - Trailer Mounted - Tier 4 (A63689)
2013 Atlas Copco...
2011 Peterbilt 6x4 Water Truck w 52,000 GVWR, and 2,000 Gallon Tank (A63689)
2011 Peterbilt 6x4...
2025 Kubota L3902HST w/ Kubota LA526 loader - 1 hour and new financing
2025 Kubota...
UNVERFERTH PERFECTA II 18' FIELD CULTIVATOR (A63291)
UNVERFERTH...
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
2007 John Deere 644J Articulated Wheel Loader (A59228)
2007 John Deere...
