Grading Rear drag blade: offset vs sliding, 5' vs 6'
   / Rear drag blade: offset vs sliding, 5' vs 6' #11
everythingattachments.com is the place to go. Check out the product videos and you will learn all you need to know.
Happy tractoring!
I agree with the others, atleast a 6ft. blade. I use mine mostly for snow. If you use the box blade on your drive you won't have a crown. I work a quarter mile drive and the box blade keeps it smooth as a baby's hind end.
Forgive this newbie question, is it not possible to tilt the box blade enough to maintain a crown?
Next question/observation is this: would my tiny tractor be able to pull a 7' blade with dirt in front of it? I have no experience with this particular size blade so figured I'd ask people with experience.
I agree, a heavy blade is more productive/useful but $/ft is more than I can cough up for the nicer blade. But, I could heavy up the blade by adding 100lb or 45 lb barbels. Is this something folks around here do to compensate?
I see that the majority prefer at least a 6' blade. What about the offset vs sliding, any idea as to the longevity and effectiveness with either design? Structurally speaking, it *seems* that the sliding blade is more reinforced since the main tube is stationery and not held on using a single pin. Of course, the Land Pride (and other similar) HD blade referenced above is made with lot of beef but it's way out of my price range unfortunately.
I'm enjoying the discussion, thank you!
   / Rear drag blade: offset vs sliding, 5' vs 6' #13
I have an 18-year-old Bush Hog 60-06 rear blade, which is pretty light duty. I find it works fine without any added weight for re-shaping my gravel driveway, provided I wait until there is enough rain to add some moisture to the road. Waiting for that is not a problem since I need the moisture for the newly graded surface to pack with traffic - otherwise the gravel just gets thrown to the side anyway.
See this thread for photos.
I don't see any need for a heavier blade.
   / Rear drag blade: offset vs sliding, 5' vs 6' #14
Yes you can build and maintain a crown with a box blade.
As far as how heavy a blade to get, if you are only working with loose materials, you are fine with a lighter blade. If you need to "work" the blade, then adding weight to a light weight blade works for a relatively short period of time before the stresses that are exerted from that additional weight take their toll of the light weight construction of the light weight blade.
I think that those of us that are recommending a heavier blade realize that a heavier better constructed blade will work better and last longer than a light weight blade. Many of us have gone the less expensive route on the first go around and then had to step up to the heavier implement for one reason or another.
You asked if your tractor is heavy enough to handle a 7' blade. Did you get your tires loaded, or is your tractor unballasted other that of the attachments-implements that you have on the tractor? No filled tires equals a 6' blade in my book. Filled tires and you can handle a 7' blade just fine.
As far as the slider vs the pivot, the pivot type offset is by far stronger and immensely easier to offset. Take a good look at the slider, major PITA if you ask me as well as putting more stress on everything. A pivot offset takes seconds to offset, a slider will take minutes at best and that is if the blade is clean.
As far as getting by with a lighter duty blade, yes you can "get by", but a heavier blade works by far better and should hold up for as long as you have the tractor.
Anything that I have said is just from my experiences both using and reading what others have said. You are the one that has to pay for and use what you get. If the linked to units are what you are choosing from, as in one or the other, get the offset pivot unit, you will be by far happier IMO.
Good luck with whatever you decide to do. ;)
Thanks Brian, your inputs are very valuable to me, nothing beats real world experience in my book. I do love the heavy duty blades and maybe someday I'll find one used locally. It's *almost* tempting to find a used, ugly blade, then build the rest myself out of 4x4x5/16" tubing and the usual beef/gussets/etc.
Edit: I forgot to answer Brian's question, the tires are NOT loaded.
   / Rear drag blade: offset vs sliding, 5' vs 6' #16
How soon do you need a rear blade? I may sell mine and get a full hydraulic heavy duty model. I am in Ruidoso so not that far away. No bends or warped edges everything is straight.
   / Rear drag blade: offset vs sliding, 5' vs 6' #17
Does that one provide for offset?
   / Rear drag blade: offset vs sliding, 5' vs 6' #18
Would my tiny tractor be able to pull a 7' blade with dirt in front of it? I have no experience with this particular size blade so figured I'd ask people with experience.
I cant find a weight for your tractor, but Im guessing its the equivalent of a small L series Kubot. ~ 2k# plus loader. That is quite adequate for a 700# 7' blade. I have used our Rhino 7' offsetting type blade on a 2010 JD and our Kubot B9200. These bracket the L series capability. The JD can damage/bow the blade by brute force, but its right near the limit of the controlled force available. Thats a 2WD 6k# tractor. The 4WD 1500# B series HST is able to do useful work with the blade but would not be able to damage with controlled force. No loader or loaded tires. ... I have not used the blade, except to plow snow, on our loader equipped Ls but I bet it would be a good match. If they were HST I would definitely be using it on them. I think your tractor of similar weight and HP with HST would work ideally.
I think your need a heavier duty blade than the ones linked ... and I think you have the tractor to handle it well.
larry
   / Rear drag blade: offset vs sliding, 5' vs 6' #19
Yes it has extra sets of predrilled holes to move the blade to either side. At 7' wide it should work well for the OP.
I have a borrowed blade currently so there is no hurry. I like your blade, looks heavy duty enough for my needs! I see that it can be offset but I'll need to add the "rotating" feature. Looks like you got the TnT feature, I'm so jealous!! Someday I'll get mine from Brian............
PM me with specifics and let's see what we can work out.
Thanks.
2017 Chevrolet Colorado Crew Cab Pickup Truck (A53422)
2017 Chevrolet...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A54814)
2012 Freightliner...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A52705)
2017 CASE IH 580...
UNUSED PABREAK METAL BUCK SHOOTING TARGET (A57193)
UNUSED PABREAK...
2014 Kubota BX25D (A53317)
2014 Kubota BX25D...
UNUSED FUTURE 20' WROUGHT IRON BI-PARTING GATE (A57193)
UNUSED FUTURE 20'...
