3ph root ripper build
/ 3ph root ripper build #1
LD1
Epic Contributor
Central Ohio
Kubota MX5100
Got alot of welding to do tomorrow. All prices are cut and prepped. Not sure how effective it will be ripping roots outbut its intended to be a multi-purpose attachment to clean up debris from fencerow removal. Uprooting trees with the BH leaves alot of trash behind. Also will be used to bust up ground so the loader and blade can move dirt easier.
/ 3ph root ripper build #2
Can't wait to see it done! I've been thinking about making a quick attached single shank ripper. Interested to see what you put together.:thumbsup:
I have a single shank knife edge ripper. Works real well tearing through roots. What you cannot pull through, lifting the hitch usually does the trick. But it cannot get real close to a tree, so I made one for the BH. And. The single shank, while nice for slicing through, don't really unearth or gather debris. That's why I decided to go this route.
The single shank was also nice for doing invisible dog fence through the woods at my last house.
/ 3ph root ripper build #4
Do you have a picture? Trying to get ideas.
/ 3ph root ripper build #5
I'm anxious to see this too. Looks Professional Grade to me LD1. :)
finished product
Tested it out a bit. It dont like heavy sod as it tends to ball up. But dirt it works as expected. Grabs roots nice too. More tractor would be nice, but it does just what I expected it to. Set it to cut about as deep as a disc, and it leaves results that look just like running a disc. Only without the noise and without the disc wanting to throw the back of the tractor around
How did you fab the rippers?
Rippers were just 1/2 x 4" bar, cut with the plasma on the appropriate angles. The notches were done in a mill. And the "tooth" is just a 6.5" long piece of 1/2 x 1-1/2 with a little grinder work.
And here is the picture of my single shank ripper:
Its 2x4x1/4 wall tubing. The knife edge is inserted in the tubing on an angle through slots cut in the mill. That knife is 1/2x2 bar that is sharpened. SO if I cannot pull through a root, raising the hitch slices it nicely.
/ 3ph root ripper build #10
I like it! Thanks.
/ 3ph root ripper build #12
Great fab LD1. Can't wait to see how it works. Looks like it could be useful for a lot of stuff.
/ 3ph root ripper build #14
I see you put a heavy bolt in the center and a smaller on on each end of the frame. Are you planning on being able to turn it to an angle.
/ 3ph root ripper build #16
Here is mine FWIW: <img src="http://www.tractorbynet.com/forums/files/build-yourself/444592-3ph-root-ripper-build-forumrunner_20151020_172046-png"/>
What's the cat 2 pin in the drawbar for?
NO angle. wouldnt really work trying to pull the teeth sideways.
ITs made to spin 180 degrees
/ 3ph root ripper build #19
I threw a real simple one together for my Father last year, when he wanted to pull out a bunch of small trees.
444651d1445440521-3ph-root-ripper-build-img_20151021_101215-jpg
Ford Pickup Truck Bed (A61568)
Ford Pickup Truck...
UNUSED SDLANCH SDLD25 MOBILE HYD DUMPER (A62130)
UNUSED SDLANCH...
2022 John Deere Z720E Zero Turn (A63116)
2022 John Deere...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
(96) 1"X8"X10" PONDEROSA PINE BOARDS (A62131)
(96) 1"X8"X10"...
43018CFL (A59228)
43018CFL (A59228)
