Kubota B2630 Diff Lock
/ Kubota B2630 Diff Lock #1
tyler101
Member
Ohio
Kubota B2630
My diff lock will not engage anymore and just clicks upon depressing the pedal. Anyone know cost of repair for this? Any chance I could do the repair?
/ Kubota B2630 Diff Lock #2
It depends on the problem. If the diff-lock is broken inside (most likely) then it is a big job. Pulling the HST and removing the differential is the only fix.
If you put off the repair, you risk further damage due to chunks of metal floating around and getting caught where is doesn't belong.
This is of course assuming your diff-lock is broken inside.
213111 (A64276)
213111 (A64276)
Unused 12-16.5NHS Skid Steer Wheels and Tires (A61572)
Unused 12-16.5NHS...
2015 FORD F-150 LARIAT CREW CAB TRUCK (A63276)
2015 FORD F-150...
2022 Weber CR 5-II HD Reversible Plate Compactor (A61572)
2022 Weber CR 5-II...
2017 Kubota M7-151 Premium MFWD Tractor (A61307)
2017 Kubota M7-151...
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
