Massey 231 Power Steering
/ Massey 231 Power Steering #1
Travis_R
Livingston Parish, LA
Yanmar YM2500
I have a 1998 MF 231 tractor. Will be repacking 1 of the power steering cylinders this weekend because it started pouring fluid out a few days ago. While I'm into it I'd like to go ahead and change the filter in the power steering pump. I know it's never been done and the tractor's almost 18 years old. How do I get the filter out? Does the pump have to come off or do I just remove the center bolt from the rear of the pump cover then pop the cover off? Also what is the best way to flush out the old fluid from the system? I'd like to go back with synthetic if possible. It takes Dexron III fluid and the engine is a 3 cylinder Perkins diesel model AD3.152. Anybody have a good parts diagram breakdown of the pump?
Thank You
/ Massey 231 Power Steering #2
Attached is a picture of the pump from the parts book online. It appears the center bolt is removed and can is popped off.
As far as flushing, remove the steering lines from the cylinders and let the oil drain out of the steering motor while turning the steering wheel back and forth. With the front wheels jacked up, move the wheels stop to stop to expell the oil in the cylinders. Of course, rebuilding the one cylinder and replacing the filter will drain the oil out of the cylinder and pump reservoir.
The online book is found at agco parts books dot com
/ Massey 231 Power Steering #3
Both my Massey 245s have 1 cylinder and a tie rod between front wheels. The 231s have 2 cylinders?
/ Massey 231 Power Steering #4
Oops, Tom, it's been awhile since I have been around the MF 231 or 245s and was thinking in general that they had two cylinders. Thanks for clarifying.
/ Massey 231 Power Steering #5
Well they might, I don't know. Seems odd that they would, seems they could oppose each other that way if a cylinder hangs up. I just know my 245s have one and a tie rod.
Yeah the 231 has 2 power steering cylinders, 1 on each side...2 power steering lines on each side of the tractor.
I got the filter out of the pump this evening. The only way I found to completely remove the pump cover is to take the starter off! I left it on and was barely able to get the old filter out. Got to order the new filter now. The old one really wasn't in that bad of shape being almost 18 years old.
I got the cylinder apart also. The seal kit has a lot of parts that won't be used. I hope it's the correct kit.
/ Massey 231 Power Steering #7
Where did you get kit from for steering pump
Hey Fireman!
What is the serial number for your Massey Ferguson 231? (Not the 231S).
My 231 was a 1998 year model. I highly regret selling it!
There’ll be a black tag on the right side of the tractor (if sitting in the seat). It’ll read something like “Made in Poland by U-R-S-U-S”.
I need the serial number off that tag because there were 3 different pumps that could’ve been installed on the tractor from the factory, depending on the serial number/ year model.
By the way, my grandfather, his 2 brothers, my grandfather’s son (my uncle), one of my great uncles, and a cousin of mine all retired from the Baton Rouge Fire Department many years ago.
/ Massey 231 Power Steering #9
Hey Fireman!
Mine is 231S and SN is U30207043. I have been retired 3 years now with 30 years in service and was able to do it before age 50. Thanking God
New/Unused Quick Attach Hydraulic Rock Hammer (A65583)
New/Unused Quick...
New 4400lb All Steel Adjustable Gantry Crane (A62679)
New 4400lb All...
Kubota V3300-T-E2BG Turbo Diesel Engine - 3.3L - Pump Takeout - Tier 2 (A63689)
Kubota...
New Mini Skid Steer Grapple Bucket (A62679)
New Mini Skid...
2017 Ford F-150 XL (A64127)
2017 Ford F-150 XL...
2019 ATLAS COPCO QAS 25 T4F NB-3 PHASE GENERATOR (A60429)
2019 ATLAS COPCO...
