Oil & Fuel Front axle fluid
/ Front axle fluid #1
buck12
Mississippi
Kubota 5460HSTC
I am in the process of servicing the front axle on my 2615 for the first time. I bought hydraulic/transmission fluid as specified in the manual. I drained the fluid and soon as I cracked the drain plug I thought that smells like gear grease. So I double checked the manual and found that the lubrication table specifies "transmission oil, front diff. oil" as "hydraulic transmission fluid" however in the section that covers front axle oil change it specifies "oil type" as "SAE 85W-140 Gear Lubricant". What do you experienced Mahindra owners use?
/ Front axle fluid #2
I think either would do the job, but Mahindra recommends the Hytran, and that is what most people use.
/ Front axle fluid #3
The owners manuals often have conflicting information. :confused3: I put the 85-140 gear oil in my 3215. After all, it is for the GEARS. Like Galen said, both would work though.
/ Front axle fluid
I'm going with gear oil because that is what I drained out of it. I don't understand why manuals are written and printed to such poor standards.
/ Front axle fluid #5
For whatever reason, I have found that the owners manual for my 7520 is pretty good and I cannot think of any conflicting info that I have found in it. Now the manual for the 3215 is another story, many conflicting things in it. I guess that we should be glad that they aren't as bad as what it sounds like the Korean manufacturers have. :laughing:
/ Front axle fluid #6
This just goes to show how confusing the operator's manual can be as on one page which is the lubrication table it says to use Hydraulic transmission fluid and then later in the MFD section is says to use the 85-140 gear lubricant. And then in the service manual (2005) they have the 85-140 to use. And I'd bet this problem is the same with all the Mitsubishi/Mahindra manuals.
/ Front axle fluid #7
I have no doubt. Probably have someone or many people writing the manuals that have never even seen a tractor. And that is no joke, my niece writes instruction manuals for a biiiiig company, she has to tell people how to work on or install stuff that she has never even seen let alone knows anything about! :shocked:
/ Front axle fluid
The best manual I have ever seen came with an old IH Scout I owned for several years. I think you could have used this manual to do everything to that truck short of rebuilding the motor. Everything else I have purchased has a joke for a manual. The Mahindra manual though is probably the worst because of conflicting information.
/ Front axle fluid #9
Sorry to resurrect an old thread. This has come up again recently, but I'm curious what exactly the MFD fluid is? Is it hydraulic oil or gear oil? I'm looking in my manuals and its obvious there is conflicting information specifying what are very different types and viscosities of oils. I'm talking specifically for the front diff oil (for MAX 25) it refers to "MFD fluid", "Mahindra Universal Tractor Fluid, and also "Mahindra EP gear oil SAE 80W-90". The "EP" in the gear oil tells me there are extreme pressure friction modifiers that the hydraulic oil would not normally have. This may or may not be important with limited slip clutches. Furthermore, 80W-90 is a lot heavier than hydraulic fluid and certainly not 85-140!
/ Front axle fluid #10
The hydraulic fluid, and the 80-90w gear oil, are basically the same thing. That's why they are interchangeable in that application, depending on certain factors.
Hydraulic transmission oil, is gear oil. It has to be, to lubricate the transmission gears properly. The only difference is some of the additives. EP gear oil gives an extra degree of protection for hypoid gears, which may or may not matter, if you use it.
No, the 80-90w gear oil is not a heavier viscosity than the hydraulic oil. Gear oil is not measured on the same scale as motor oil, which leads to people incorrectly believe that it is thicker. Pour both side by side, and you will see they are basically the same viscosity. If that doesn't convince you, do a timed viscosity pour test.
Viscosity varies widely by brand. But, they are both around 30w, at room temp., if you compare them on the motor oil scale.
/ Front axle fluid #11
Hydraulic fluid is a 30w.
If you don't know what to put in it, pull the drain plug, then you'll know. Gear oil will be near black and smell badly and hydro fluid will be much lighter in color and consistency. I'd argue that hydro is not the same thickness as the gear oil. I've worked alot with both.
BTW, my 3016 manual is pretty clear...hydro fluid.
/ Front axle fluid #12
Many people have trouble accepting this. Sorry, it is not opinion, It is fact. Test them for yourself.
80-90w is not dark, and does not have the familiar burnt smell. Those are the heavy gear oils.
You must not have worked with much 80-90W. It is clear, and thin.
Here is a chart that shows what I am talking about:
/ Front axle fluid #13
I've worked with 80-90 and the heavy gear oils in the past, as I've had many Model T's and A's. They all took 600w gear oil but sometime in the 1980's it was decided that the 80-90w was just as good and I've been using that.
Granted I haven't done much work on them in the past 20 years or so, so maybe the 80-90w stuff has changed, but back then it was much thicker and darker than what is called hydraulic tractor fluid (30w) today.
The UTF stuff I just put in my tractor is a clear light yellow color, almost the color of urine and that's not the way I remember the 80-90 stuff I used before...it being very dark and thick...and smelly...not as dark, thick, and smelly as the old 600w but sufficiently so that it's easily recognizable as gear oil.
Perhaps the stuff has changed as I haven't used any 80-90 for a while. My restoring old car days went away as I tore off more and more pages of the calendar.
Your chart does show that the 80-90 stuff starts at the very top of the 30w range and goes up to the 50w range. I would have expected it to be much higher up the scale based on my past experience.
I bow to your knowledge of current oils.
/ Front axle fluid #14
Ray66v-
Your chart is proving you somewhat differently. Viscosity testing is normally rated in kinematic centistokes (cSt) at either 100'C or 40'C on the left (more common) or Saybolt Viscosities on the right. What you are trying to show (which is correct) is representing SAE engine oils with other ratings(ISO, AGMA, SAE Gear oils,) within the different rating standards at those given temperature ratings. You are right in that ENGINE Oil ratings are not the same as GEAR oil ratings, however, you are ill advised in making the assumption that Tractor Hydraulic Fluid is an SAE ENGINE oil and comparing it to an SAE GEAR oil. Tractor Hydraulic Fluid is not represented in the chart.
So, to be fair lets look at what brand X rates their viscosities are at 40'C and 100' cSt. ... I did a quick internet search and found:
http://www.sinclairoil.com/pdfs/pds/universal_tractor_hydraulic_fluid.pdf
Mobilfluid 424
The specs for Sinclair brand shows 63.53 @ 40'C cSt and 9.76 @100'C cSt. The Mobile 424 shows 55 @ 40'C cSt and 9.3 @100'C cStwhich puts it closer to an AGMA 2 or ISO 68.
Conversely an SAE multiweight gear oil such as specified 80W- 90 is rated higher at 147.7 @ 40’ cSt and 14.7 @ 100’ cSt- closer to an AGMA 4 or ISO150 (needless to say 85W-140 is even higher at 371.1/26.96 @ 40/100’ cSt)
http://www.sinclairoil.com/pdfs/pds/automotive_gear_oils.pdf
https://mobiloil.com/en/gear-lubricants/mobilube-hd-plus
Conclusion: Universal Tractor Fluid is indeed a lighter weight oil than 80W-90. You are right however, in what I think you are trying to convey in that SAE Engine and SAE Gear oils are in fact rated different.
(Ill be happy to enroll you in the professional development courses I teach on just such a nature. :thumbsup:)
/ Front axle fluid #15
Ray66v-
Mobilfluid 424
Conversely an SAE multiweight gear oil such as specified 80W- 90 is rated higher at 147.7 @ 40 cSt and 14.7 @ 100 cSt- closer to an AGMA 4 or ISO150 (needless to say 85W-140 is even higher at 371.1/26.96 @ 40/100 cSt)
As I said, viscosity varies dramatically. If you pick the right two products they will be closer. Compare the same product from different manufacturers, and they can be widely different. That is another thing people don't realize. Two 30w oils can have a fairly different viscosity.
For all intent and purpose, they are similar enough to be considered the same, in most cases.
I said, they are BASICALLY the same, and that is true.
And, as I said, if you do a timed pour test, you will not see significant differences. It's been done, to try and prove this wrong in the past.
Most people's conception of 80-90w is incorrect.
The technical aspects, and splitting of hairs are not important, as to the fact that either is completely interchangeable in this instance, as a front axle lubricant. All I am trying to convey is, the reason why is, they really aren't different.
Some refuse to accept it. I'm fine with that. Only trying to help those who are interested.
/ Front axle fluid #16
80-90 for the diff. use the hyd fluid for cold weather climates and winter use.
/ Front axle fluid #17
Either fluid is acceptable and will work fine for the Max series tractors. We use the Mahindra UTHF in them when servicing them in the shop and have never had a problem. My understanding is years ago they used 80w90 in the front axle, but at some point they found the transmission/hydraulic fluid meets the specs for it as well.
/ Front axle fluid #18
This thread is a prefect example of why this site is so valuable. As a relative newbie to the tractor world things sometimes get confusing. Earlier today "Mahindra Don" posted a video of the basic service for a Max tractor. He mentioned the hydraulic fluid for the transmission and to make sure NOT to put gear oil in there. He went to the MFD and showed what to do there, and mentioned that this is where the gear oil went. That confused me because the owner's manual says to use hydraulic fluid. Lo and behold, a few hours later this thread pops up and clears up the confusion. There is a world of knowledge on here from guys who have been there and done that. Us newbies can learn a lot of valuable lessons here without having to learn the hard (and expensive) way of trial and error. Thank you to all of the old pros who share your knowledge with us rookies.
2013 Felling 25' x 102 Tag Trailer (A62613)
2013 Felling 25' x...
20ft Shipping Container (A61166)
20ft Shipping...
New/Unused Open Backing Plate (A61166)
New/Unused Open...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
2022 CATERPILLAR 289D3 SKID STEER (A62129)
2022 CATERPILLAR...
2013 Freightliner CASCADIA DAY CAB (A59575)
2013 Freightliner...
