increase hydraulic pressure
/ increase hydraulic pressure #1
alanjb
North GA
Kubota 3830
Can I increase my pressure to help the FEL and 3pt. I have a L3830 and need to lift 2 hundred more pounds
/ increase hydraulic pressure #2
First, the answer is yes. I also have a 3830. I have had it less than a year and suspect that the relief was set too low.when it went back to the dealer for the first 50 hr service I complained. Book says it should be 2650psi. mine was only 2400psi. It is raised by installing shims of different thickness on the relief spring.
/ increase hydraulic pressure #3
would you have a diagram of the location of the relief spring, some directions. I am not a mechanic as you can tell
/ increase hydraulic pressure #4
I was wondering if you could help me with the exact same problem, I need directions as as I am not mechanical. Maybe you direct me to a diagram?? What ever help you can give me. AJ Ryan
/ increase hydraulic pressure #5
Hello AJ
I'm a mechanic and encourage people to do their own work. The work that Deerlope talks about is quick, easy, and commonly done. But working on the pressure relief valve - which happens to be the primary hydraulic safety valve, BTW - is one of those simple operations that takes specialized tools (gauges & shims) plus some understanding about the forces and hazards involved in changing the settings. I'm sorry; this is one of the few times when you really do need to take it to a real mechanic.
I'd feel more comfortable advising you on how to rebuild just about anything else from steering to starter....and including the engine.
Good luck,
rScotty
/ increase hydraulic pressure #6
The thread was from 2003!
AJRY, please start a new thread, and give us some info on your machine and why you want to increase the pressure. The first step is to get a gauge setup and test what you have to see if it's in spec. We have a video posted on our website showing how to do it-and we offer a ready made gauge as well.
2017 Ford Expedition SUV (A61574)
2017 Ford...
2019 Chevrolet Express 2500 Cargo Van (A61573)
2019 Chevrolet...
Rake Master CR-72G (A64119)
Rake Master CR-72G...
2002 Ford Ranger Pickup Truck (A61573)
2002 Ford Ranger...
PTO GENERATOR ON TRAILER (A63291)
PTO GENERATOR ON...
2013 Bomag BM-211D Vibratory Soil Compactor (A61572)
2013 Bomag BM-211D...
