Work lights
/ Work lights #11
I did the Drill, baby DRILL method (hole in the ROPS). :shocked:
/ Work lights
I'm considering drilling a small hole to run the wires to keep them out of harms way. A 1/4" hole in 3" wide tubing shouldn't hinder the ability of the rops.
/ Work lights
I'm guessing these are made overseas
/ Work lights #15
Anyone with a cab model (I have a B2650 cab version) mount LED lights, and where on the cab?
/ Work lights #16
Seems like I have seen photos of aftermarket LED lights mounted just below the top of the cab (always a good idea) using factory mounting points, maybe with DIY brackets. Just make them stiff enough that you don't get harmonic vibrations from the running tractor.
FWIW, I mounted my wire looms to the ROPS by drilling (yes!) 3/16" holes, and tapping for #10-32 machine screws, then using cable clamps. I think small holes are less of a concern than larger ones. Plus, I wouldn't want water to get inside the ROPS. The brackets are some 11/2" x 1/4" alum. angle I had... easy to work, and stiff.
/ Work lights #17
Agreed. I used black tape to hold my wire for now. I think I'll drill & tap, with zipties with mounting hole! Thanks for the mention of tapping, that's clean. Theres other ways too, the Ziptie saddle mount (for .25" wire bundle). I've used the adhesive mounts, sometimes they just come off, I don't think they are for outdoor use and they only stick to the materials they LIKE (for long periods). I guess a guy could JBweld nuts onto the ROPS (no drill).
If little holes in the ROPS increase danger, then could weld up all the un-used (large) holes in the tractor main frame to increase safety. It could be like cap & trade. You get to drill 5 little holes in the ROPS if you weld up one big hole in the frame. Sorry, Hogwash alert. :D Your tractor should work for you, not you for it. Except where you ENJOY working for it. Or being a rebel. Man that's some stick-it-to-the-man! :laughing:
If you want lights, the ROPS is the OBVIOUS location, so drill some little holes (IMHO). And when people say "aren't you worried about the ROPS? Say "YES I am, if the tractor tips over I hope to keep inside the safety zone". And you can add "honestly I'm more worried about reversing over an embankment so I added better lights".
/ Work lights #19
Sodo, I too tried the adhesive mounted cable clamps, and they.... fell off. I am too cheap to buy the aerotech type mounts that 4shorts and some others rave about. 3/16" holes don't count in my book.
Husqvarna Riding mower (A56857)
Husqvarna Riding...
2022 John Deere R4023 (A60462)
2022 John Deere...
2017 John Deere 6195R (A60462)
2017 John Deere...
2006 CATERPILLAR D604S GENERATOR (A58214)
2006 CATERPILLAR...
2009 CAROLINA  16FT EQUIPMENT TRAILER (A58018)
2009 CAROLINA...
2023 Chevrolet Express Van, VIN # 1GCWGBFP8P1104620 (A61165)
2023 Chevrolet...
