Tiller unknown tiller is broke
/ unknown tiller is broke #1
jerrywa1234
Monroe, WA
John Deere/4200
I have this made in Japan tiller and I've broken the chain. Does anyone recognize this make?
I would like to be able to repair it instead of buying new since I only use it sparingly.
It appears as though it was originally a light blue color. Of course I had no idea the gear lube in it was so foul.
/ unknown tiller is broke #3
any dealer should have some chain that will fit it
/ unknown tiller is broke #4
Looks like a standard roller chain.
Should have the size stamped on the links of the old chain.
Find the size, count the links and get a new chain.
thank you! that makes sense. clean up the chain and have a new one made. the cover did sustain some damage but I can repair that and
pound out a new gasket if one is not available.
thanks. I had forgotten that "fact" about roller chain..................size being stamped.
I got out the file for the tractor today and in fact, I had retained the invoice from when I purchased the used tiller. it is listed as a Mitsubishi.
/ unknown tiller is broke #8
Looks like it was run with water in it. I would check all the bearing too. Moving parts don't get along with water.
154 (A52708)
154 (A52708)
2012 HAMM 3410P PAD FOOT ROLLER (A62129)
2012 HAMM 3410P...
(4) Bridgestone 11R22.5 Semi Tires (A62177)
(4) Bridgestone...
New/Unused Hydraulic Thumb for CFG Mini Skid Steer (A61166)
New/Unused...
2014 CATERPILLAR 320EL RR EXCAVATOR (A62129)
2014 CATERPILLAR...
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
