Do your own Fluids and Filters on a BX
   / Do your own Fluids and Filters on a BX #361
Re: Hydraulic fluids for BX24
i have been reading page after page of this thread in hopes of finding specifics on how to check and add hydraulic fluids for my BX 24(purchased second hand a few months ago with only 90 hours of use!) I want to add a hydraulic powered wood splitter and down to hooking up new lines from my hydraulic lines to the splitter, will need to add some fluid for the splitter cylinder. However, in reviewing my owners manual front and back several times I Find no references to how to check or change hydraulic fluid. On this thread I found reference as to how to drain fluids and clean the cigar shaped filter from 2010 but so far no reference on checking levels or adding fluid. AzNearest dealer is 100 miles away. I'm a newbie at tractors but determined to do as much as I can. Any guidance or suggestions would be much appreciated!
   / Do your own Fluids and Filters on a BX #362
Combo dipstick/fill hole plug on the HST behind and below the seat. The pinkish thing in the pic.
   / Do your own Fluids and Filters on a BX #363
Well shucks, no sooner did I post my message than I realized what now seems obvious- the transmission and hydraulic fluid are one in the same source! I check the dipstick just to the right and above the PTO and I Assume that's where I fill in new fluid. My local farm dealer doesn't have the Kubota brand transmission fluid for transmission/hydraulics and thinks no problem mixing his with the Kubota fluids, offering me AGCO Permatrans 821XL. Any opinions?
   / Do your own Fluids and Filters on a BX #364
Some Kubota Bx owners have reported possible reduced cold weather performance by not using SUDT or SUDT2. Some have reported more whine from the hydrostat using some other fluids. I don't know, I am just repeating "what I heard"
:2cents: I. Me. Personally would never use anything but SUDT or SUDT2 (SUDT2 replaced SUDT several years ago but some dealers may have SUDT left and it works OK) in the transmission of a Kubota HST. Surely you, friend or family member will be going by or near a Kubota dealer some time in the future. If all else fails it can be ordered on line or on the phone from a Kubota dealer and your friendly UPS or Fed Ex person will bring it to your house. It's an expensive experiment to try a different brand and discover it doesn't function as well as the Kubota branded product for which most Kubota HST owners are satisfied with. Many dissatisfied users that have tried to save a few dollars or save a trip and installed a different brand. :2cents:
   / Do your own Fluids and Filters on a BX #366
I have a B7800 hydro that I switched to two different fluids and ultimately switched back to SUDT2. There's a thread on it somewhere but the bottom line is the SUDT offers less gear whine and "tighter" starts than with other brands of fluid. Maybe it's part or all synthetic but it's SUDT2 for me in Kubota hydros.
   / Do your own Fluids and Filters on a BX #367
I will not get into the yeas and nays on SUDT2 as I have stated my thoughts many times as late as on the previous page this thread. The NAPA I use is their 85-405. Specs match SUDT2 and I am happy at 1600 hours on a BX25. If you go that route their negotiate for their fleet discount or military if eligible.
Ron
   / Do your own Fluids and Filters on a BX #368
Ron
Who knows... maybe the NAPA brand is from the same formulator as Kubota? Anyways with anything there are different grades, qualities, etc. Best to do your homework and listen to experience. Cheers, Ron!
   / Do your own Fluids and Filters on a BX #369
This is probably already out there but I think you can look at the MDSS (Material Data Safety Sheet)and determine who the manufacturer is and cross check to other makers to see if they are the same. no guarantees they will have the same additive packs but it's a start.
   / Do your own Fluids and Filters on a BX #370
I run Mystik JT5 since the previous owner used that in the tractor and his other Kubotas for lots of hours.
   / Do your own Fluids and Filters on a BX #371
there are several for Kubota UDT, but SUDT2 has no one else that meets the spec. Generally in gear drive tractors, or those in warm climates UDT is fine, SUDT is worth the extra money for those in the north or in smaller HST transmissions where the whine is most noticeable.
   / Do your own Fluids and Filters on a BX #372
   / Do your own Fluids and Filters on a BX #373
Most of the Kubota dealers I've visited down here in Texas don't carry anything but UDT, and have told me SUDT and SUDT2 is not necessary in our warm climate.
I'm using UDT in my BX23, but I did order SUDT from you guys for my BX2660.
   / Do your own Fluids and Filters on a BX #374
As noted earlier, SUD2 gives less gear white and better starts in my B7800 and in the middle of summer when it's 85 degrees or more. I notice the difference in summer and I can compare to the other brand fluid I tried earlier. Just my two cents here.
   / Do your own Fluids and Filters on a BX #375
How does SUD2 give you better starts? I hope you're not putting it in the motor...........
   / Do your own Fluids and Filters on a BX #376
Just drained and refilled my B-7800 with SUDT2. To be honest, I can't tell any difference in the sound or performance, but it's not cold yet.
   / Do your own Fluids and Filters on a BX #377
I've used several different types of fluid in my BXs including SUDT and honestly can't tell any difference. I bought some SUDT2 for my L5740 to see if it makes any difference; does fine as is, just curious.
   / Do your own Fluids and Filters on a BX #378
3R, I am with you. I have used NAPA 85-405, 1500 hours for my BX. Just had some HST work done at the dealer (unrelated to lubrication) and they filled with SUDT-2. They charged over $100 for less than 3 Gallons. As far as my experience goes there is no whine factor, they both sound the same. 85-405 is a multi season oil also, heavy duty, and developed by Warren Petroleum for the newer tractor HSTs. SUDT-2 is made by Ashland Oil who also maker Valvoline.
Ron
   / Do your own Fluids and Filters on a BX #379
Ron
That NAPA 85-401 / 85-405 is what I use in my Kioti DK50SE.
Just for information for others reading this, 85-401 and 85-405 are the same thing, the 85-401 is the 1 gallon jug and the 85-405 is the 5 gallon can. It is the NAPA Premium heavy duty hydraulic fluid. It is an all-season fluid.
   / Do your own Fluids and Filters on a BX #380
First, no gear whine now in my B7800. I had whine with a different brand and by better starts I mean that there is less hesitation and a faster response when I step on the pedal. My guess is the SUD2 is a full synthetic and if you found another full synthetic that met specs it would probably work. It wasn't worth my time so I'm going with SUD2. It's not the cost of the SUD2 that's the issue but rather the difference in price between what you might use and the price of the SUD2. It's probably $10 or $20 or whatever and that's no big deal. It's not going to make me poor or Kubota rich so I'm OK with it. It's nice to support my dealer as well if I'm going to spend a few $$.
Honda UTV (A56859)
Honda UTV (A56859)
2019 Dodge Charger Sedan (A59231)
2019 Dodge Charger...
SHOP BUILT TOOL TRAILER (A58214)
SHOP BUILT TOOL...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60460)
2019 International...
2018 CASE 340RT TRACKED TRACTOR (A60430)
2018 CASE 340RT...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A56438)
Ditch Witch 6510A...
