Gate Hinge
/ Gate Hinge #1
SandburRanch
NHtd75
Anyone ever use this type of gate hinge?
/ Gate Hinge #2
I've used weldable hinges but not for gates. I would imagine large ones for that application might prove cost prohibitive. Lots of other options available.
To attach an aluminum checker plate tool box lid to my steel fuel transfer tank I purchased one aluminum hinge and one steel, then mismatched them.for welding.
Terry
/ Gate Hinge #3
If you do use this type be sure to keep it well greased/lubed.
Have seen some where opening a gate or steel door that has been not used for a time will tear or ripped the hinge from the weld...
Not a problem if the hinge gets used often.
/ Gate Hinge #4
Used these on my heavy blast booth doors. I think these would work excellent on a gate.
/ Gate Hinge #5
We used those pretty much exclusively on OI gates. What you want to do is match the hinges to the post and hinge end of the gate before you build the gate, much easier to have just one end to deal with than an entire gate.
/ Gate Hinge #8
They look similar to these that I use ... They also have a ball bearing
Barrel Hinges - 5"
The problem with that type of hinge is that a security gate can just be lifted off the hinge when you only have a two piece hinge. For flat services like a loading dock, one can be turned in each direction to prevent shifting, but on a horizontal gate that is not the case.
/ Gate Hinge #10
My gates have two, the top and bottom supporting the load and the middle one reversed so there is no way to lift off the gate without first taking out the middle hinge.
JOHN DEERE 310K (A58214)
JOHN DEERE 310K...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
AMERICAN 14 T/A DOG HOUSE (A60736)
AMERICAN 14 T/A...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
3PT Boom Pole (A60463)
Giyi Mini Ex Attachment Set (A60463)
Giyi Mini Ex...
