How often does your tractor Regen?
   / How often does your tractor Regen? #11
Two regens in 36 hours for me. Obviously, not working it real hard with mostly grapple work and some FEL work.
   / How often does your tractor Regen? #12
I have the exact same tractor and I go through one about every 24 hours. I work mine at about 2000 rpm and when the light comes on I kick it up to 23/24 for about 10 minutes when the light goes out. And it definitely smells!
Thanks for the replies guys! this tractor spends 75% of its life with a 7' finish mower behind it at 540 pto speed so im sure that has a lot to do with not having a regen yet. I do remember when I bought my truck brand new it went twice the miles that other guys were saying was normal for a regen before the first one...then after that they come like clock work at 500 miles lol. maybe im experiencing that again with the tractor.
   / How often does your tractor Regen? #14
I have a larger tractor, M135GX. During the first 400 hours it would regen from 15 to 22 hours. Last winter they replaced the computer due to a rough power shift complaint I had from day one and now it goes from 40 to 70 hours. One lucky thing my larger tractor has is the ability to display DPF temperature and percentage plugged. Last week I had one day when I was working it extremely hard and I gained only 2% in that day. The next day, easier implement, and I gained 8% in my 10 hour day. The dealer mechanic said the computer does not only use pressure sensors to establish regen frequency but uses other parameters in its calls. The day it went up only 2% - hard pull, DPF temperature seldom below 1,000 degrees. DPF temp I see during regen is 1080 to 1125. The second day with lighter pull DPF temp was normally in the 900 to 1000 range. My tractor is one of the first M135GX's built so the computer change reflects user experience. It also now defaults to auto regen. With the first computer I always had to push the auto button every time I started. Now I found out if I press auto it is actually inhibit. So even for one model there may be different regen times depending on the year the tractor was built.
Thanks MHarryE! my button defaults to auto on my L3901. I get home from offshore tomorrow and will be working the tractor a good bit while im in so I should see a regen at some point. I just want to make sure that everyone else has a light come on the dash when it is in regen so that I am not wasting my time looking out for it and when it does come on I know to not shut the tractor down and let it finish the cycle
   / How often does your tractor Regen? #16
My L3901 is about the same and I do the same thing when the regen light comes on.
   / How often does your tractor Regen? #17
I've also got the same tractor. Mine did it's 1st regen at 8 hrs but I think the fuel that came in it wasn't as clean. it was offroad diesel and filled up the water seperator. Most of my running has been at 2400rpm (540pto) pulling either a 72" finishing mower or a 60" bush hog. 2nd regen came at 38 hrs. Tractor now has 65 hrs and hasn't done 3 rd regen yet. Both times light on dash came on and stayed on for approx. 15 min. Hope that helps.
   / How often does your tractor Regen? #18
My first regen on my 3901 happened at 38hrs. Im only at 42 hrs now so not sure on the second yet. I did notices right away from the smell and looked down to see the light on the dash. Took about 15 mins for the light to go off. I kept mowing the whole time and other than the smell I would have never known.
   / How often does your tractor Regen? #19
Here is the regens for my tractor:
DateHoursElapsed
01-17-1516.016.0
02-28-1528.812.8
03-29-1540.011.2
05-05-1553.113.1
07-14-1568.615.5
10-24-1581.512.9
   / How often does your tractor Regen? #20
My L3301 hit 15.1 hrs and went into its first regeneration. I raised the Rpms up to 2300 until the rpm increase light went off and let it run. The outside temp was 40 degrees. It finished and light went off 18 minutes later.
(Only reason I know is I had read about it here and was curious as this is my first exposure to the whole thing)
2018 Chevrolet Tahoe SUV (A55973)
2018 Chevrolet...
2022 Brush Wolf 4800X Severe - Duty Excavator / Backhoe Brush Cutter (A57024)
2022 Brush Wolf...
1608 (A57192)
1608 (A57192)
2000 Volvo VNL Sleeper Cab Truck, VIN # 4V4N21JF6YN250211 (A57453)
2000 Volvo VNL...
2020 DRAGON ESP...
Champion Dual Fuel Portable Generator (A54816)
Champion Dual Fuel...
