How often does your tractor Regen?
   / How often does your tractor Regen? #41
Understood. Thanks for the clarification. :thumbsup:
   / How often does your tractor Regen? #42
My old 2015 Kubota L3901 DT would regen every 15-20 hours, sometimes as little as 10 hours depending on what was being done for tasks. My new 2017 L3901 HST just turned over 46 hours today and hasn't even done it's first regen. The old DT L3901 would idle down a lot due to direction or gear shifts so I attribute a lot of regents to that. The new HST tractor has been run at a constant 2000-2500 RPMs since day one.
   / How often does your tractor Regen? #43
LS 3032, every 4 hours. Would not know it was in regen if not for the indicator light
   / How often does your tractor Regen? #45
Regens on my MX5800 vary from 6 to 20 hours depending on how hard I work the tractor. My new L6060 has 12 hours on the clock and the intellipanel shows the DPF is at 35%.
   / How often does your tractor Regen? #46
My new L4060 didn't Regen until 40 something hours the first time. Hit my 3rd Regen yesterday at 90ish hours.
   / How often does your tractor Regen? #47
Scratch what I said earlier, it finally did its first regen at 48.6 hours today.
   / How often does your tractor Regen? #48
My L3901 has 53 hours and if it regen'ed I never knew it but it's possible it did it according to some. I don't see the lights unless I look down at them which I don't do when I'm working. I do a short startup high idle and then rpms to PTO speed notch/mark on tach and never run it under that till I turn it off.
   / How often does your tractor Regen? #49
Wow! Some of you guys have regens a lot more often than I do. My 2014 L3560 has 300 hrs. on it and I just went thru my 4th regen. The dealer told me to be sure to push the auto-regen button every time I start the tractor to turn it on. It burns off the carbon while working. The newer Kubota's regen button automatically comes on when started so you don't have to turn it on manually. I asked if they could wire it like the new ones, but they said they couldn't. I find that hard to believe, but that's what they told me. Just run the tractor like **** and it will burn most of the carbon off while working, and when it does regen, I just up the RPM's and keep on working until it's done.
   / How often does your tractor Regen? #50
My L4701 did a regen at 35 hours. That was the first time I noticed it. The light is in the upper right hand corner and kind of hard to see in bright sunlight. I'm wondering if it has done it before and I just didn't notice. I really did not notice anything different while the regen was taking place. Only inconvenience is that it started about the time I was ready to stop for the day. So I just kept working the tractor for another 15 minutes or so until it was finished.
2014 Ford E-450 Super Duty Shuttle Bus (A56858)
2014 Ford E-450...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
New Holland TS6.120 Power Shuttle 4WD 120HP Agricultural Tractor (A56857)
New Holland...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
2022 FREIGHTLINER CASCADIA SLEEPER (A56129)
2022 FREIGHTLINER...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A57880)
2019 KENWORTH T680...
