WICKED Utility Grapple!!!
/ WICKED Utility Grapple!!!
The first sold Wicked Utility Grapple is being loaded onto a trailer right now!
It will spend most of it's time hooked to a NX6010 Kioti. A match made in heaven!! :thumbsup:
Travis
/ WICKED Utility Grapple!!! #23
The 73" Wicked Utility Grapple page is now LIVE on our website. See it here: Mega Compact Utility Grapple - Free Shipping!
I'm anxious to see your first 55" unit. I have an 84" Blue Diamond on our New Holland TL-100A that is used for moving dead trees etc. but it weighs 900 + lbs with 34" jaw opening.
I want a narrower grapple with max opening strictly for tree limbs and brush and will install on my LS XR4046HC (46 HP / 2500 lb. FEL lift).
Looking forward to hearing about final weight on the 55".
Sent from my iPad using TractorByNet
/ WICKED Utility Grapple!!! #24
I'm anxious to see your first 55" unit. I have an 84" Blue Diamond on our New Holland TL-100A that is used for moving dead trees etc. but it weighs 900 + lbs with 34" jaw opening. I want a narrower grapple with max opening strictly for tree limbs and brush and will install on my LS XR4046HC (46 HP / 2500 lb. FEL lift). Looking forward to hearing about final weight on the 55". Sent from my iPad using TractorByNet
Couldn't you use the big grapple for brush and get their medium duty 54" single lid wicked grapple for trees? I move trees with my light duty 48 Millonzi all the time. My loader has 2760lb capacity so similar to yours. Better net lift capacity for trees with a smaller grapple. Big grapple for light brush would work fine too.
/ WICKED Utility Grapple!!! #25
Rock on!
/ WICKED Utility Grapple!!! #26
Ted, I think you have done a great job in designing this latest grapple! Having elongated the bottom tines is to my opinion a very good thing. Capacity is not only increased, but operator view will gain from it as well. As for the lids, I find them very well designed, and bracing second to none. The twisting forces will well be attenuated.
The only drawback, is the lack of protection for the cylinders.
Your design department has worked hard to get such a well balanced grapple!
Will be nice to have some pictures of your 55" model as well...
/ WICKED Utility Grapple!!! #27
IT;
Guess you did not read my comments. The BD Grapple only opens to 34". Great for trees but, a PIA for brush and limbs.
I want the 55" EA grapple for the 42" jaw opening.
/ WICKED Utility Grapple!!! #28
IT; Guess you did not read my comments. The BD Grapple only opens to 34". Great for trees but, a PIA for brush and limbs. I want the 55" EA grapple for the 42" jaw opening. <img src="http://www.tractorbynet.com/forums/files/attachments/442605-wicked-utility-grapple-image-169714617-jpg"/> <img src="http://www.tractorbynet.com/forums/files/attachments/442606-wicked-utility-grapple-image-2413611461-jpg"/> <img src="http://www.tractorbynet.com/forums/files/attachments/442607-wicked-utility-grapple-image-1308434597-jpg"/> Sent from my iPad using TractorByNet
Got it. But in that case why not just ditch the big grapple. The EA would handle both trees and brush.
/ WICKED Utility Grapple!!! #29
The 84" grapple has only been off the NH twice in 3 years to use bucket. Now that I have the XR4046 HC to do dirt work, the grapple may never come off. Same with the Bush Hog cutter.
I'm also anxious! I think it will outsell the larger one because of the lighter weight and compact size that will be easier to maneuver.
I'll share pics and weight as soon as I can!
Travis
/ WICKED Utility Grapple!!! #32
I'm also anxious! I think it will outsell the larger one because of the lighter weight and compact size that will be easier to maneuver. I'll share pics and weight as soon as I can! Travis
Thanks Travis.
/ WICKED Utility Grapple!!! #34
Here is one of my pet rocks.
And the pet rock pile. :D
Eric's looks like a pet. Those others.....not so much! :eek:
Travis
Beautiful weather here in NC today, so why not hook up the new grapple and try to break it? Sounds good to me. :D
That's what Ted did this morning. We weren't planning on photos/videos, but I was there and couldn't resist.
We'll have a new how NOT to use a root grapple video soon!
Travis
He was headed towards me, but I got out of the way!
There were some gnarly vines in the woods, so he was able to twist, turn, push and pull in every direction, giving the grapple everything the L6060 could dish out!
attachment.php
A better view of the grapple hooked up. Ted sat on this tractor for the first time today.
2024 14ft Pairboat Flat Bottom Mud Boat (A64557)
2024 14ft Pairboat...
2018 International Durastar 4300 Asphalt Pot Hole Patcher Truck (A64556)
2018 International...
2007 JLG G6-42A 6,600lb 4x4 Rough Terrain Telehandler (A64553)
2007 JLG G6-42A...
2014 Takeuchi TB260 Midi Excavator (A64553)
2014 Takeuchi...
2026 SDLANCH SDLMG1220F Galvanized Metal Livestock Shed (A64194)
2026 SDLANCH...
KUBOTA TE6583T - 6 BASKET HAY TEDDER (A64278)
KUBOTA TE6583T - 6...
