Looking at new truck
/ Looking at new truck #21
I have an '04 Chevy 2500 with Duramax I am considering trading soon. I need a diesel due to the multiple hills and mountains pulling my horse trailer here in East TN. I am still leaning toward another Chevy/GMC primarily because I like the GMC automatic locking differential over the electronic locker design that Ford uses. Makes a difference between going home or calling a friend for a pull when trying to get my trailer out of some spots.
/ Looking at new truck #22
2500 plus airbags does not get you bigger bearings, or brakes or tires or rear GAWR all of which is key when your pushing heavy pin weights from 5th wheels
3/4 and 1-ton trucks are identical in every way except for the rear springs. 1-tons generally have an extra overload..but that's it. Now, when you step up to a DRW, then you get a heavier axle.
Many 3/4 tons have a "camper package" you can option them with that will give you the 1-ton springs...
/ Looking at new truck #23
3/4 and 1-ton trucks are identical in every way except for the rear springs. 1-tons generally have an extra overload..but that's it...
Well, not exactly every way. They also differ in how much the sticker on the door says you can legally haul. Yes, you can upgrade the springs, but to the best of my knowledge, there's no way to change the legal definition of your GVWR.
/ Looking at new truck #24
Buy the truck rated to pull the loads you require, from the best dealer in your area no matter what brand! I have a 2014 2500hd duramax the exhaust break is awesome, combine that with Allison transmission and it sure does give you confidence when hooked to big load?
/ Looking at new truck #25
With a gooseneck trailer, watch out for the tongue weight. We had a 3/4ton and when we bought the horse camper, the rear axle was overweight even without water or horses! We upgraded to a 1 ton (2007 Chevy) and have been happy with the truck. I can't say about anything newer, we haven't looked at trucks in 8 years and don't plan to.
Our 2007 C3500 rides good. My only complaint is that a crew cab dually is hard to fit into shopping center parking lots! It's also a tight fit with oncoming traffic on our one lane roads here.
/ Looking at new truck #26
With a gooseneck trailer, watch out for the tongue weight. We had a 3/4ton and when we bought the horse camper, the rear axle was overweight even without water or horses! We upgraded to a 1 ton (2007 Chevy) and have been happy with the truck. I can't say about anything newer, we haven't looked at trucks in 8 years and don't plan to. Our 2007 C3500 rides good. My only complaint is that a crew cab dually is hard to fit into shopping center parking lots! It's also a tight fit with oncoming traffic on our one lane roads here.
yeah, I am pretty much stuck on a SRW one ton. The 2500 sure was nice to drive, but the payload ratings on it were not much more then the current half tons.
Right now there are three options I am looking at:
*Pick out one of the three brands and buy in the next six months, currently my preference is towards the Chev
*Wait until the 2017 super-duty is available and then go shop the three brands
*option three, there is a dealer advertising an XLT new at $18000 less then the SLE GM I drove, with similar options, both diesel. It is also $13,000 less then my nearest Ford dealer. I am going to talk to them and if the deal is as is, and not just a gimmick to get me in the door, then I think a new Ford will be in the near future.
/ Looking at new truck #28
Agreed. It may handle the load but get pulled over withe the GVWR exceeded and your busted.
Chris
I am less worried about being pulled over than I am about overloaded tires blowing out. With a dually, you have four tires to share the weight. When we bought our horse camper, I could feel the rear end "give" on very gentle curves with the F250. I got it weighed and we were 300# overweight on the rear axle with an empty trailer. The C3500 dually is totally stable. It's not overloaded.
You can add air bags and you might go to more ply tires but that isn't going to get you what two additional wheels will give you.
Ken
Deleted
/ Looking at new truck #30
That's news to me. A duelly in MA needs commercial plates due to the definition of commercial vehicles in MA. More than 4 tires touching the ground is commercial (there is more to it) . A single rear wheel one ton does not meet that definition so it should not need to be registered commercial. Unless there was a change in the law that I'm not aware of. Some of the inspection stations will try to scam the more expensive inspection for vehicles over 10K, but if it is not registered commercial it should be $35.
Thanks for the reference. This contradicts what I've been told at the registry though. My dually 87 dump in my avatar was registered with personal plates, where as my friends newer SRW F350 pick-up had to be commercial. The registry told the both of us that is was based on the manufactures rated GVWR. May truck was rated 10K lbs and his was over. I registered mine in Wilmington I think. The registry in Springfield made him get a notarized statement indicating that it would not be used for commercial purposes.
This was about 5 or 6 years ago though, so it may have changed. I wish it was more clear cut.
I should also state that I heard that GM GVWR thing from a dealer, so that could be total malarkey. Should have prefixed my post above with: "A rumor I once heard..."
/ Looking at new truck #31
I have been told different thing on my trailers here in texas. I looked it up for myself, took the information to the state registration office and told the what I wanted.
Got my farm plates on one trailer for $5.30 with no inspection due. Got normal plates with inspection due for $67.00 on another. Got a third trailer no plates no inspection for farm use under 4000 lbs. Got US Army Veteran plates on a fourth for $67.00.
Things the bureaucrats did not/would not tell me.
/ Looking at new truck #32
Sounds like trucks can be a lot less to register depending on where you live.
My 1985 C20 Van is still almost $200 a year and we don't have the option of going non-commercial... even with cars like old Chevrolet ElCaminos and Ford Rancheros...
/ Looking at new truck #33
Farm plates on my F250, Mazda MPV delivery van, and now my Jeep wrangler. All registered at 12,000 lbs, which is the lightest weight class for farm vehicles (still can't exceed GVWR or GAWRs of course). Each vehicle costs $45/2 years, or $22.50/ year. Can't complain about that!
Only stipulation is that I can't drive them to a non-farm occupation. Fine with me.
/ Looking at new truck #34
3/4 and 1-ton trucks are identical in every way except for the rear springs. 1-tons generally have an extra overload..but that's it. Now, when you step up to a DRW, then you get a heavier axle. Many 3/4 tons have a "camper package" you can option them with that will give you the 1-ton springs...
Don't forget tires and wheels. When I bought my 05 Dmax 3500 you could not get aluminum wheels. Reason was the capacity was only sufficient for a 2500. I had to get steel wheels.
On my 06 F350 it had 17 inch wheels vs 16 inch wheels on the F250.
Chris
/ Looking at new truck #35
Chris
I believe you were fed a line of BS by someone at GM. Plenty of new 1-ton pickups on the lots with AL wheels. F450's too. ****...nearly every tractor trailer on the road runs AL wheels. My cheap aftermarket wheels on my 3/4-ton Ram are rated at 3600lbs each.
The wheel size on your F350 VS the F250 is just an option package. Brakes are the exact same size, wheels/tires/axles/front suspension....all the same between a F250 and F350 SRW.
/ Looking at new truck #36
For what it is worth, my 06 F350 SRW, 11,400 GVW has personal plates. I purchased / registered it about 3 years ago....
/ Looking at new truck #37
Thanks mbrule.
Goes to show the confusion here. My info was first hand, but again, that was about 6 years ago that we registered our trucks.
/ Looking at new truck #38
Chris
no 05+ ford F250/350 had 16" rims, 16" rims wouldn't clear the calipers. 17" were as small as you could go 18" were an option
true
/ Looking at new truck #39
no 05+ ford F250/350 had 16" rims, 16" rims wouldn't clear the calipers. 17" were as small as you could go 18" were an option true
Standard rim size on F250 was 17 inch and F350 had 18" as standard.
/ Looking at new truck #40
1988 Ford Mustang GT Convertible (A61574)
1988 Ford Mustang...
2023 Freightliner Cascadia 116 S/A Day Cab Truck Tractor (A61573)
2023 Freightliner...
18.4-38 Clamp On Rear Duals w/Rims (A64119)
18.4-38 Clamp On...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
John Deere 6200 Tractor (A64047)
John Deere 6200...
2025 Future X39 Hydraulic Trencher Skid Steer Attachment (A61572)
2025 Future X39...
