jaln
Member
My alternator is not charging.
It probably has not for some time and I have gotten by charging with a battery charger and replacing batteries.
The tractor runs a long time without the alternator charging.
I have two schematics for my T233, one in a service manual, and one in an owners manual.
Both are barely readable. You can't blow them up because they are not vector drawings, just bitmaps.
Does anyone have a vector version so I can easily read the darn thing?
I have tested the continuity of the large stud on the back of the alternator with the fat white wire.
It looks like it should connect through the 50A Alternator Fuse on the firewall, and then back to the starter solenoid stud, and then continue to the positive side of the battery.
Therefore, I should get zero resistance from the alternator stud, to the stud that the fat white wire on the starter solenoid connects, and which connects also back to the positive terminal of the battery.
I get an open connection, infinity, so I think the 50A fuse must be blown.
Anyone have a generic part number for that fuse and/or any advice?
