My first tractor...Yanmar YM240
/ My first tractor...Yanmar YM240 #1
burke385
Nashville, TN
Yanmar YM240
Hello all, I'm new to the forums and new to the world of tractors. I just completed my first purchase, a Yanmar YM240 that I found locally on Craigslist. The prior owner was an older farmer a few towns over, who used it mainly for mowing his 2 acre lawn at the house. Other than that, he just tinkered with it in the garage. I think that it's in pretty good shape, very clean, and you can tell he took care of his equipment. He was good enough to offer to deliver it to my cabin about an hour away, so that was the icing on the cake and made it too good of a deal to pass up.
I bought this with the following goals in mind: mowing my 1.5 acre lawn around the cabin, clearing out approx 2 acres of overgrown pasture, and finally putting in some food plots for next year's deer season. It came with a finish mower, so now I'm in the market for a roto tiller and maybe a brush mower (have a DR field and brush mower, so I can alternatively do some brush clearing by hand).
I'm looking forward to learning as much as possible thanks to the other good folks on here, and I'd like to ask two questions off the bat. Please pardon my ignorance, if applicable!
1) The throttle does not stay where set for more than a second or two, having the tendency to move downwards towards off. From reading around, I think this is a pretty common thing, but couldn't find a discussion of the problem for this particular tractor. Any tips on how to modify the linkage to get it to stick in place?
2) I wanted to get it good and greased, but I have no idea what type of grease the prior owner used. Should I be concerned about mixing greases in any place in particular? Is there a safe bet on what to use, or is it best to find out if possible? (I plan on calling and asking the prior owner, but just in case he doesn't know either).
Ok thanks so much for your time, look forward to learning as I go.!
20150924_120705.jpg20150924_120650.jpg20150924_112434.jpg20150924_112440.jpg20150924_125926.jpg20150924_125931.jpg
/ My first tractor...Yanmar YM240 #3
Welcome!
You have good taste! (From another YM240 owner). :D
There are several owners on here, and lots of discussion recently.
That is immaculately clean, the guy took care of it. You'll love it.
For the throttle holding position, there's a washer between the movable and fixed parts, where the throttle lever is attached to the firewall. I made a replacement washer for mine but I don't remember what I used, maybe fabric-backed sheet rubber from an old boot. Preferred, buy the right washer from Hoyetractor.com. They have anything you might ever want for this.
/ My first tractor...Yanmar YM240 #4
Welcome to the forum. :welcome: Nice looking tractor. There is also a double nut on the end of the throttle lever. Could be a little tightening could solve your loose throttle. See item 12 on this 2000 drawing. Throttle works just backwards from yours but friction on it is the same. Yanmar Tractor Parts: THROTTLE
lubricants: Fluid & Oil Types
/ My first tractor...Yanmar YM240 #5
Welcome aboard from another YM240 owner! I've had mine about a month and have found this forum to be invaluable. That's a great machine you've got. VERY clean.
When I got my machine the throttle lever was so loose it would rattle down due to vibration and stall the tractor. As Winston pointed out there is a double nut on the pivot point of that lever. I tightened that and it will now stay where I put it. Maybe your problem is as simple as that?
Enjoy you new machine. She sure is pretty.
/ My first tractor...Yanmar YM240 #6
When I got my machine the throttle lever was so loose it would rattle down due to vibration and stall the tractor. As Winston pointed out there is a double nut on the pivot point of that lever. Look to the inside of that mounting flange where the throttle lever pivots (in your final two pictures). I tightened that and it will now stay where I put it. Maybe your problem is as simple as that?
/ My first tractor...Yanmar YM240 #7
No doubt you don't have the correct Nylon washer. Looks to be a round Wire brush? Also be careful tightening it up. It also looks as though the handle may have already been broken from over tightening it. Trust me it doesn't take much to break it. I broke off the Threads of mine.:shocked: really easily!! I was able to weld them back and here's a pic. of what the Nylon washer fits like. Fredricks Outdoors mailed me the correct one in a Reg. Env..
Welcome!
I've noticed the great community support on this site (and others). I sure am glad that I decided to go for it and get this tractor!
I've been browsing hoyetractor.com and am impressed by their parts support.
I suspected it might be something this simple, just didn't have much time to play around with it when I accepted delivery at my property. Will check this first the next time I head out there. And thanks for the suggestion to check parts on the YM2000 page on hoyetractor.com, I hadn't thought of that, and was wondering where the throttle parts were for my YM240.
I'm going to be tempted to spend some extra time keeping it looking clean, althought I have plans to put it through its paces!
Thanks for taking the time to snap a pic. I know exactly what to look for now!
As far as safety upgrades go, a ROPS is of course tops on my list. I plan on purchasing from Hoye Tractor. Anybody have experience with their product? How was the installation? Are there other OSHA certified ROPS out there (I'd rather go that route than having somebody fabricate something for me).
Also, is this tractor equipped with an overrunning clutch already? This seems to indicate so, but I've read conflicting this on these forms. When I took it for a test drive, I didn't know to check for it with the mower attached, which I can always do to be sure the next time I get on it.
/ My first tractor...Yanmar YM240 #12
I found the OEM throttle washer dried, inflexible, split and bulging out on mine. My first attempted replacement cut from sheet neoprene was too sticky. Second one made of fabric-backed rubber sheet still works fine a couple of year later.
California, 10-4. I've got the one from Hoye sitting in my basket as we speak. Now to just load up with other goodies to make the shipping worth the while.
/ My first tractor...Yanmar YM240 #14
Yes, the 240 has a built in over run clutch.
/ My first tractor...Yanmar YM240 #15
I bought Hoye's first one for YM240, and one of the first ones they sold for anything after production started. We assumed the ROPS certified for YM2000 would fit YM240, and I confirmed it did with just very minor grinding needed on the (non-stock??) spacer that mounts my fenders a little higher. I posted about it here in 2006:
http://www.tractorbynet.com/forums/yanmar/75272-rops-ym240-ym2000-pictures.html
The ROPS also makes a good place to install a golf bag to carry shovels, chain, etc.
http://www.tractorbynet.com/forums/customization/85360-shovel-carrier-golf-bag.html
These all have the overrun clutch inside the transmission. Get an implement spinning and cut the throttle. Like when you quit pedaling a bicycle, there's a ratcheting sound.
/ My first tractor...Yanmar YM240 #17
View attachment 442179View attachment 442180View attachment 442183View attachment 442184View attachment 442181View attachment 442182
you need to either tighten the throttle shaft up and or need and new friction disk. You can buy it at Hoye but the shipping will probably be more than the disk. I think there like $1 each? This is a good chance to get new fuel and oil filters while your there.
grease. Dont worry about it you can mix greese just like oils. That is a wives tale. Maybe there is two hugely different greases that cant mix? but they all work togeather that i know of. Cheap black molly grease works or you can go as expensive as you want with mobil 1 or something if you want.
/ My first tractor...Yanmar YM240 #18
yes, but i see winston answered that a little below this.
You can also call Aaron at Hoye and ask. They will mail you something small in an envelope and charge you like $2 to do so. Will work for orings and things like this.
/ My first tractor...Yanmar YM240 #19
I don't know how much shipping is for a rops from Texas, but you can get everything you need from
403 Forbidden in Hartselle Al.. probably a couple of hours drive from Nashville.
/ My first tractor...Yanmar YM240 #20
Don't know what 403 forbidden means, but the link still works for Fredricks
United Box Blade (A64047)
United Box Blade...
2013 DODGE RAM 2500 CREW CAB TRUCK (A62130)
2013 DODGE RAM...
2013 CHEVROLET 2500 HD (INOPERABLE) (A63569)
2013 CHEVROLET...
2016 VOLVO EC250EL EXCAVATOR (A64279)
2016 VOLVO EC250EL...
DRILL CABINET SKID (A60736)
DRILL CABINET SKID...
2016 Case IH Magnum 310 Tractor (A64047)
2016 Case IH...
