Quick Hitches Skid-Steer Quick-Attach Mount (Male Loader Side)
/ Skid-Steer Quick-Attach Mount (Male Loader Side) #1
ShadyTree
Lansing, MI
None
Does anyone have dimensions of Skid-Steer Quick-Attach Mount (Male Loader Side)? I'm trying to build one, saw uhmgawa and someone else posted dim's & pic's, but can't find 'em now. If anyone can help navigate to links or re-post, I'd sure appreciate it! Thanks,
/ Skid-Steer Quick-Attach Mount (Male Loader Side) #2
It sound's like you're switching and you'll be needing a ssqa "plate". I'd just get one and do a little "reverse engineering". I've got a wooden template for the vertical dimensions and both angles (for building the attachment side) that I could measure it you like.
I'm building the male side that attaches to the loader arms, the part that has the levers and pins that attaches to the ssqa plate. Thanks anyway...
/ Skid-Steer Quick-Attach Mount (Male Loader Side) #4
Borrow or even rent a good name brand bucket or forks, any attachment that mounts by SSQA and use it for a "JIG" to build the loader side That's the way I built the one for my kubota, and everything I've ever hooked it to fits very well.
/ Skid-Steer Quick-Attach Mount (Male Loader Side) #5
That's what I meant with "reverse enginer" it. A plate (the fm side) should give you all the dimensions that you need to build the tractor or "male" side with the exception of the levers. If I were building one, I might try to locate some of the lever/springs & pins for the latching mech. from a skid steer or tractor and just buy those parts. Here is one place that might sell the whole part from a used machine Wengers Of Myerstown - Farm Equipment, Agriculture Equipment, Tractor Parts, Construction Equipment, Construction Parts and I'm sure that there are others around the country. What is your project? And :welcome:
/ Skid-Steer Quick-Attach Mount (Male Loader Side) #6
/ Skid-Steer Quick-Attach Mount (Male Loader Side) #7
Thanks, Rustyiron! We do have this equipment.
/ Skid-Steer Quick-Attach Mount (Male Loader Side) #9
Go to your local skid steer dealer and buy one (that they have in their junk pile) that they've replaced for some reason. I've bought two and they charged about $100 each.
/ Skid-Steer Quick-Attach Mount (Male Loader Side) #10
This side is what he wants.
If it is in there junk pile, I don't think I would want it.
/ Skid-Steer Quick-Attach Mount (Male Loader Side) #11
That's the side I'm talking about.
They may have removed it because the pivots were wore out where it attaches to the skid steer arms on the loader. You don't use the pivots when you retrofit it for a tractor anyway as you make your own brackets.
I've bought two of them and they work great.
/ Skid-Steer Quick-Attach Mount (Male Loader Side) #12
OK, it would look more like the SSQA on my wife's Toolcat.
/ Skid-Steer Quick-Attach Mount (Male Loader Side) #13
yes very similar. I ground the back side flat and then welded all new brackets (a friend cut them on their CNC plasma table) on the back. Basically converted a John Deer tractor to accept skid steer attachments on the FEL which is sweet! Any skid steer attachment that doesn't require hi-flow I can now use on the tractor.
I'm making the same thing but will go on the 3-point on the back. Using a skid steer male quick attach. So then if I put my skid steer forks on the back and use a hydraulic top-link I'll be able to not only raise and lower the forks but I can tip them too. Since the 3-point will lift a lot more than the FEL I can use it for the really heavy stuff.
/ Skid-Steer Quick-Attach Mount (Male Loader Side) #14
SSQA measurements
30 Yard Dumper (A61166)
30 Yard Dumper...
UNUSED SDLANCH SDLFP30 EELCTRIC PALLET JACK (A62131)
UNUSED SDLANCH...
UNUSED RAYTREE RMSC78 - 78" HYD SOIL CONDITIONER (A62131)
UNUSED RAYTREE...
BUYERS PREMIUM & PAYMENT TERMS (A59910)
BUYERS PREMIUM &...
VWS Toolbox/Fuel Cell (A61166)
VWS Toolbox/Fuel...
2014 Freightliner Bucket Truck (A63118)
2014 Freightliner...
