TX1500 Rotavator PTO
/ TX1500 Rotavator PTO #21
Hey Mitch I have one of these tillers for sale however I don't know if you want to pay fright shipping as I live in Wisconsin.
/ TX1500 Rotavator PTO #22
[HI, Thanks again for all the great info on the tiller.
I am interested in accessing the manual for the TX1510 by any chance as I am having alternator trouble as it does not seem to be charging teh battery. Had a guy in Ireland look at the winding bushings etc but the bushings are fine but the winder seems shagged. Only option seems to be to buy new as I have tried a few scrap years and a local tractor scrap yeard but no avail!
Any suggestions as it seems to be a fairly rare piece of kit and quite small to usual ones!
Cheers
Torin
/ TX1500 Rotavator PTO #23
Hi Torin, Welcome to the Group!
I have a pdf of the 1300-1500, I think it will serve your purposes, however I tried to upload it here just now and TBN told me it was too large for their service, I will try and cut and paste the electrical section for you!
/ TX1500 Rotavator PTO #24
Hi john, thanks that would be great. Otherwise I could pm you my email address and you you email me the PDF? Cheers t
/ TX1500 Rotavator PTO #25
Might this help?
100 New Alternator Iseki Tractor TU1900 TU2100 3 Cyl Diesel 1982 1988 | eBay
I have a small ebay business, if they will not ship overseas I could receive it and ship to you.
Also since it is a 12v alternator I have seen other (handy) guys take any known good working alternator and fabricate brackets to mount it up. (Just a thought) (Someone here I think did it), it did not fit inside the factory sheet metal but it worked. (PS I am not handy at fabrication so I do not actually know how difficult this would be)
/ TX1500 Rotavator PTO #26
hello all I have TE3210 and the SR1100CD but cant fit them together as the PTO has not mounting plate around it to attache the tiller too..... i have looked on the manual for the tractor and tiller and both show this mounting plate but enither exsplain what its called or where i could get one from.
done any body know what the plate is called which is mounted around the PTO and holds the tiller to the back of the tractor?
It seems my only option is to have a plate is fabricated?
do these plate come with the tractors or supplied with the tillers?
PS its quite old mid 80's
thanks Martyn
/ TX1500 Rotavator PTO #27
thanks Martyn
/ TX1500 Rotavator PTO #28
/ TX1500 Rotavator PTO #29
here my tractor with the missing back plate which the tiller would mount against
/ TX1500 Rotavator PTO #30
Here's my SR1100CD tiller which i am struggling to mount to the ack of the tractor!
/ TX1500 Rotavator PTO #31
Hi Martyn:
I have a 1500 and a tiller that mounts like yours. I had to look at your pics and my tractor to understand what you need. I do not know what it is called, I am sure you could get one from West KY tractor parts . com West Kentucky Tractor Parts , Shaffer Tractors Sheaffer's Town & Country Tractor and possibly Valley Power . com
If you can not get it from one of the above, one of them will know where you can get it. You need a used part, I do not think Iseki makes these parts anymore.
Fabrication is an option for you, you need two outward facing pins like you see in my pics on a plate with four bolts, this plate also holds the top link for 3 point attachments. A PO has removed this needed plate to add the remotes, I believe as the top link 3PH would be in the way of the rear remotes. I believe your tractor was modified to hydraulically run a pull behind "thingy" or backhoe? or other thingy,
(Because without a top link it can not lift anything).
Not sure if I helped you in anyway, if I can give you more information do let me know.
John
