lights for plowing
/ lights for plowing #1
farm boy00
Howard City, MI
John Deere M&MT, Case 1030 comfort king, Sears ST16, Craftsmen 6000, homemade articulation mini-loader
/ lights for plowing #2
For your setup I'd go with 45w LED floods instead of 36w. The prices have come down a lot. Here's a pair for $82. 2 x 6 inch 45W CREE LED Flood Offroad Driving Work Light Bar Lamp Offroad Car | eBay I just put four of these on my NX4510HST cab, two front and two rear, from the same seller for about $148. I'm real impressed with the quality.
You can find a pair of 45w spots for a little over $62, if spots will work for you.
/ lights for plowing #3
I have three 27 watt LED floods on my tractor, and they light up the place like a football stadium. They go for $10 each on EBay.
Plastic ones? ?
/ lights for plowing #6
/ lights for plowing #7
they have a swivel bracket the will allow you to mount them from the back or the bottom. Sorry don't have pic of that. I mounted them with the mounting bolt down.
/ lights for plowing #8
they have a swivel bracket the will allow you to mount them from the back or the bottom. Sorry don't have pic of that. I mounted them with the mounting bolt down.[snip]
Thanks!
/ lights for plowing #9
I've posted on my lighting in other threads, but someone following this thread might enjoy seeing it. This being my third Kubota, and with each of them getting LED lighting, mostly used for night time snow removal, I have "improved" each one. I think I finally have it. I just added the 18W side lights, which I wanted since I am plowing in a fairly wooded area, and having snow covered limbs dump on you is best avoided. I guess they call it "situational awareness".
/ lights for plowing #10
I'm setting up my duramax for plowing. I'm wanting to put lights on the headache rack. 2 pointing front, 2 pointing back. This truck will also be a farm truck.
This is ebay I'm thinking
http://m.ebay.com/itm/2x-7INCH-36W-...-ATV-SUV-FOG-DRIVING-/251969693520?nav=SEARCH
I would go with a full light bar for front, like this:
Amazon.com: Eyourlife 36" 234w 16200LM 78LEDs Driving Led Light Bar Spot Flood Combo Offroad Waterproof: Automotive
Night and day difference on my tractor between the smaller lights. Note that it requires over 20A though.
On the back, those 36W's would be perfect... unless you like glare and lighting up the bed I would mount them under the rear bumper though unless you plan on getting a pull plow.
All of these choices are not DOT approved, and at least the light bar is blinding to other drivers and would only be used when plowing. Do not drive around with them on.
/ lights for plowing #11
Plastic ones? ?
No, they're not plastic. The lenses are made of silica that is bonded with ash and limestone at about 1700 degrees. The housing is made of bauxite which is run through a hot bath of caustic soda and lime and then combined with carbon and electricity.
Amazon.com: SHANREN LED Work Light Lamp Off Road High Power ATV Jeep 4x4 Tractor 27w 60 Degree Flood Light: Automotive
I've had 3 of them on my tractor for over a year, and they work great.
I guess some people like to pay more for stuff, makes them think they are getting a better product.
/ lights for plowing #12
Those are the ones I have also, except their square, 27watts is plenty for me, they really light up the night, I also have the lower wattage like "oldpilgrim's" for the back of my machine.
Landhonor 400 lb Electric Hoist (A66408)
Landhonor 400 lb...
Wolverine Quick Attach Trencher (A66408)
Wolverine Quick...
2003 PETERBILT 379 SLEEPER (A59914)
2003 PETERBILT 379...
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
King Kutter II Tiller for sale.
King Kutter II...
New/Unused ATS Grass Proof Cloth (A65583)
New/Unused ATS...
