Mounting a 8.5' snow plow on a SSQA plate
   / Mounting a 8.5' snow plow on a SSQA plate #1
Bradbilt
Gilbert PA
Ford 260C, Ford 8N, NewHolland GT22,
I have a 8.5' Western plow to go on the front of my Ford 260C.
Couple of questions...
1. should I make the plow float? Use a chain to float up and down for the incosistanceqys in the driveway.
Or hard mount it
A. I will need to back blade out from 4 garage doors
B. I will need to do a 1/4 mile long dirt drive along with a 1/4 mile of pavement
2. What size quick attach plate should I be using? I was thinking 1/2" but is that just over kill?
A. my tractor weights 10k and 4wd
   / Mounting a 8.5' snow plow on a SSQA plate #2
I welded a 3pt quick hitch to a SSQA plate for mine. Plow frame has a cross brace that fits in the lower hooks & can pivot. Chain goes to the toplink hook, so I can float or lift the plow with curl.
You will hate it if you hard mount things. It needs to float & floating the loader arms in float dumps WAY to much weight on the plow.
   / Mounting a 8.5' snow plow on a SSQA plate #3
As stated,you want to float the plow not the FEL.The pivot points on mine are 1in.bolts.
   / Mounting a 8.5' snow plow on a SSQA plate #4
Without question.
How do I back blade with the chain?
   / Mounting a 8.5' snow plow on a SSQA plate #7
Lift the arms or curl. Drive forward. Uncurl or drop the arms. Back up. Might need to repeat.
You don't have down pressure, but the blade weighs a decent bit & will pull most of the snow unless you've let it freeze up overnight.
   / Mounting a 8.5' snow plow on a SSQA plate #8
I use a seven ft.rear blade in combination with my 8ft.front.Rear blade works well for pulling snow from door ways ect.
Just back blading with no weight is not going to work for me.
I have a rear blade but it makes the tractor so Unmanuverable.
2011 PALOMINO COOL DOWN TRAILER (A55745)
2011 PALOMINO COOL...
2000 Ford Ranger Pickup Truck (A55852)
2000 Ford Ranger...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A55852)
2015 Freightliner...
2013 Audi A6 AWD Sedan (A53424)
2013 Audi A6 AWD...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
