John Deere 4720 starter problem???? Please help!!!
/ John Deere 4720 starter problem???? Please help!!! #1
fordsmoke
New London, Iowa
John Deere 4720
Im across a creek and no way to tow home so I need to fix where its at. When I engage starter it just clicks or turns the engine just slightly. Had both new starter and battery checked and there good. Cable from battery to solenoid is good. I switched relays and yes PTO is off. Please give me some ideas I need help. The seat safety switch does not effect starting. There is a code 008 but not sure it has anything to do with starter not spinning over the engine. This all begin after I ran the tractor out of fuel. I have no manual or schematic. Thank you, John
/ John Deere 4720 starter problem???? Please help!!! #2
Have you checked/cleaned,tightened ALL FOUR battery cable connections?
/ John Deere 4720 starter problem???? Please help!!! #3
If the engine turns over "just slightly", that rules out all of the safety interlocks. Jim is right of course, clean and check all four points of connection.
Can you try to jump start it to get it home?
Are you sure the battery isn't just dead from cranking it after running out of fuel?
/ John Deere 4720 starter problem???? Please help!!! #4
Sounds like a bad ground or corrosion in the terminals
Yes, Thats one of the first things I did
I even tried a new battery and run a jumper directly to the solenoid. Is it possible that the ignition could be bad? When I turn the ignition switch I can hear the solenoid ingage. When I turn switch more to engage starter it just clicks or barely turns flywheel like maybe a few teeth. Is it possible the solenoid is kicking in and out because of switch? Im screatching my head on this one.
Again all connections and cables are good, clean and fastened tight and properly. Battery is good, starter is brand new. I even had new starter checked at auto zone. So am I missing something? Starter solenoid engages with switch but just clicks when you engage starter. All I can think is maybe bad switch? Is that possible or is there something Im missing?? Any advice appreciated. Thank you!!!
/ John Deere 4720 starter problem???? Please help!!! #8
Meaning you put a new battery in the tractor?
/ John Deere 4720 starter problem???? Please help!!! #9
I'm going to make a couple of assumptions here: you or someone replaced the original starter hoping to solve a problem starting, but it has not. Neither has installing a new battery. What hours on machine and how old is it?
Here's what I suggest in the mean time. I'm suspecting a bad cable, regardless of how clean the ends may be at all four contact points of both ground and positive cable. But first:check your fusebox for any burnt or corroded fuses, to rule them out. Inspect each one carefully. Make sure there is NO corrosion at any fuse connectors.
So, do this: Make sure tractor is in neutral, brake on, etc. Take your jumper cables and attach the ground cable ONLY from it to the negative battery post clamp, and to a known to be good chassis ground. Try starting. If the engine cranks faster or starts, your battery ground cable is toast.
If that doesn't change anything, try the positive jumper cable from the positive battery post,and have someone turn the key to ON, (not crank position), while you touch the other end of the cable to the starter solenoid small terminal, where it is fed by the ignition switch, just long enough to see if the starter spins the engine fast. If you get a fast turn over on the engine you may have a bad positive cable from starter to battery plus post.
Be careful- take someone with you to be on site just to help, and for safety.
Be extra careful when using the positive cable to activate the starter, do NOT let it ground out on the starter or any other metal. Wear glasses and gloves to cover all the bases.
Curious why you say the seat switch does not affect the starting sequence?
Post back results. One step at a time to figure this out.
/ John Deere 4720 starter problem???? Please help!!! #10
You might consider asking that someone post or PM you requesting your e-mail address to send you a wiring diagram or a diagram showing the starting system for your tractor. I think with the diagram and a volt meter you will determine were the problem is.
I would also ask for assistance on the error code. The following manual shows a Err 08. I did not see a 008,
OMLVU19619_E9
Ok guys first of all I want to thank you for taking some time out of your day to help me. Ok tomorrow I will take all the fuses out and check for corrision although I have already checked to make sure all were good with tester. The tractor is hydro if I forgot to say. I have already run a jumper cable straight from battery to a good engine ground and did same with positive straight to solenoid. I will try to run it straight to the small terminal fed by switch and see what happens. I was able to start tractor without sitting on seat before. Of course if I was running pto and got out of seat it would shut off. The 008 code is for throttle sensor which says Voltage signal out-of-range or not calibrated. Do not think that would have any effect on starter but not sure??? My e-mail is Removed Private email Thanks!!
/ John Deere 4720 starter problem???? Please help!!! #12
Will it start with a screw driver? Jumping across solenoid. Try that. If so its the ignition, ignition wire or solenoid. That test will show battery cables are good.
/ John Deere 4720 starter problem???? Please help!!! #13
Ok guys first of all I want to thank you for taking some time out of your day to help me. Ok tomorrow I will take all the fuses out and check for corrision although I have already checked to make sure all were good with tester. The tractor is hydro if I forgot to say. I have already run a jumper cable straight from battery to a good engine ground and did same with positive straight to solenoid. I will try to run it straight to the small terminal fed by switch and see what happens. I was able to start tractor without sitting on seat before. Of course if I was running pto and got out of seat it would shut off. The 008 code is for throttle sensor which says Voltage signal out-of-range or not calibrated. Do not think that would have any effect on starter but not sure??? Thanks!!
Use PM, not personal emails, for obvious reasons....
The throttle sensor might control cranking, but if so it ought to eliminate it completely, not just hamper it's action.
This could be part of what needs to be fixed overall to make it run right once it starts; and probably getting your fuel gauge fixed, or your eyesight checked if the gauge is working currently.:)
/ John Deere 4720 starter problem???? Please help!!! #14
Did it truly run out of fuel?
When it originally stopped did you try to start it and these symptoms were happening then? As in starter briefly engage but not turn over?
Did the engine stall and lock is what I am fishing for here.
Ok guys I ran a hot wire from the battery to the solenoid small terminal (feed by ignition) and the starter spun right over. I checked and cleaned all fuses and nothing. Im thinking my ignition switch?? And coyote your right I need to pay more attention to my fuel gage as it would have saved me alot of hassle. Maybe I need to find out where this throttle sensor is if you fellows think that may be the problem?
/ John Deere 4720 starter problem???? Please help!!! #16
did you pump the fuel primer on top of the fuel filter?
yes but thats not the problem. My problem is to get the starter to work with ignition switch
Put in a new ignition switch today and it still does not engage the starter. I can start it by jumping across the solenoid with the switch on. This is the hydro model and only safety switch is the pto that would prevent it from starting and its fine. When you engage starter with switch it just clicks. Im going to tap into ignition today and run a wire directly to solenoid to see what happens. Any ideas??
2011 CATERPILLAR 279C SKID STEER (A65056)
2011 CATERPILLAR...
Pop Up Camper (A66738)
2016 CHEVROLET IMPALA (A66091)
2016 CHEVROLET...
Hydraulic Breaker Skid Steer Attachment (A66734)
Hydraulic Breaker...
2015 CHEVROLET CAPRICE (A66091)
2015 CHEVROLET...
2016 Chevrolet Silverado 2500HD 4x4 Crew Cab Knapheide Service Truck (A68183)
2016 Chevrolet...
