BX2200 running fine then dies suddenly, will restart but only if key held to engage s
/ BX2200 running fine then dies suddenly, will restart but only if key held to engage s #1
Baybear
Running fine then dies. Will run fine if key held in starter position. If I release to normal "on" position it dies. Bad ignition switch? other?
Will
/ BX2200 running fine then dies suddenly, will restart but only if key held to engage s #2
Fuel shut off solenoid?
/ BX2200 running fine then dies suddenly, will restart but only if key held to engage s #4
You check the fuses, if seating on the tractor, right side, behind the removable screen at your feet, I think it is the yellow one, look close at it. If not as others have said Check the fuel shut off solenoid.
You check the fuses, if seating on the tractor, right side, behind the removable screen at your feet, I think it is the yellow one, look close at it. If not as others have said Check the fuel shut off solenoid.[/QUO
Fuses are OK. Where is the fuel solenoid? Sorry to be such a dumbie?
Will
/ BX2200 running fine then dies suddenly, will restart but only if key held to engage s #7
I can get you a picture of the solinoid on my bx1800 tomorrow, assuming its components are in the same location as your bx2200.
/ BX2200 running fine then dies suddenly, will restart but only if key held to engage s #8
Will
The newer BX series has the solenoid right up top on the right rear of the engine compartment when facing forward; shiny steel/sheet metal body, tubular, maybe 3" long. I could not find the thing on my own BX2200 so far.
Just a follow up. It was the stop solenoid as suggested in the first few posts above. The solenoid is located just below the air filter hose going into the intake manifold. Thanks to all for your help.
Will
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED FUTURE REMOTE CONTROLLED TOY (A60430)
UNUSED FUTURE...
2019 Dodge Grand Caravan Van (A59231)
2019 Dodge Grand...
2016 F-250 4X4 (A56438)
2016 F-250 4X4...
2015 Ford Escape AWD SUV (A59231)
2015 Ford Escape...
YANMAR VIO35-5 UNIVERSAL EXCAVATOR (A60429)
YANMAR VIO35-5...
