Mowing CK20 HST speed/cruise control
   / CK20 HST speed/cruise control #1
Ranchofla
Leon County, FL
Kioti CK20 HST
So I am going to mow a friends field this coming weekend and decide that it would be nice to actually use the cruise/speed control on my tractor CK20 HST (it has not worked for the three years I have owned the tractor). I started messing with it last night and found the front pivot froze, so I fixed that now it appears that the spring (or one of them) at the back is not pulling as it should. I have attached the pictures I have from the manual and it appears that there are two springs (according top my parts list and MIE's list). Does anyone have a picture showing how these two springs should be installed?
The part numbers are T2360-32353 and T2360-32352
Thanks
Rancho
   / CK20 HST speed/cruise control #2
So - If you think the cruise control is going to work like your car your in for a big disappointment .
Actually I know based on the manual that it will NOT operate like my Trucks cruise, but it does what is suppose to do (after some adjustment).
thanks
Rancho
   / CK20 HST speed/cruise control #4
Thanks
Rancho
The 2 part numbers listed are for the same spring, just an updated part number. It is just a torsion spring, with the rotation arms oriented as shown in your picture. "Spring 2" is the spring that controls the cruise mechanism.
Thanks for the information, after I looked deeper into the manual I found that my issue was a matter of adjustment as the 'Lock Shoe' was not putting enough pressure on the 'Lock Arm'. When I engage the lever now it does hold the pedal down as it should.
Thanks
Rancho
2010 Ford F-450 16ft Box Truck (A55852)
2010 Ford F-450...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
2014 Toro Workman HD 07369 Utility Cart (A55851)
2014 Toro Workman...
2023 PETERBILT 567 VOLUMETRIC CONCRETE TRUCK (A55745)
2023 PETERBILT 567...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
