Mowing CK20 HST speed/cruise control
   / CK20 HST speed/cruise control #1
Ranchofla
Leon County, FL
Kioti CK20 HST
So I am going to mow a friends field this coming weekend and decide that it would be nice to actually use the cruise/speed control on my tractor CK20 HST (it has not worked for the three years I have owned the tractor). I started messing with it last night and found the front pivot froze, so I fixed that now it appears that the spring (or one of them) at the back is not pulling as it should. I have attached the pictures I have from the manual and it appears that there are two springs (according top my parts list and MIE's list). Does anyone have a picture showing how these two springs should be installed?
The part numbers are T2360-32353 and T2360-32352
Thanks
Rancho
   / CK20 HST speed/cruise control #2
So - If you think the cruise control is going to work like your car your in for a big disappointment .
Actually I know based on the manual that it will NOT operate like my Trucks cruise, but it does what is suppose to do (after some adjustment).
thanks
Rancho
   / CK20 HST speed/cruise control #4
Thanks
Rancho
The 2 part numbers listed are for the same spring, just an updated part number. It is just a torsion spring, with the rotation arms oriented as shown in your picture. "Spring 2" is the spring that controls the cruise mechanism.
Thanks for the information, after I looked deeper into the manual I found that my issue was a matter of adjustment as the 'Lock Shoe' was not putting enough pressure on the 'Lock Arm'. When I engage the lever now it does hold the pedal down as it should.
Thanks
Rancho
HYDRAULIC MOTOR AND PUMP ON A SKID (A55745)
HYDRAULIC MOTOR...
2010 Kubota ZD326 60in Zero Turn Mower (A55851)
2010 Kubota ZD326...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A51692)
2016 Autocar...
HUSQVARNA FS6600D FLOOR SAW (A55745)
HUSQVARNA FS6600D...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
