JD 4400 HST transmission chatters
/ JD 4400 HST transmission chatters #1
texasranger556
Maryland
JD 4400
Hi guys, long time lurker first time posting. Last year I bought a 4300 with a loader. Then I started looking for a backhoe for it since I'll be building a shop soon. I ended up finding a 4400 with under 500 hours in better shape complete with a 430 loader, 48 backhoe, mid PTO, foam filled R4 tires, etc. Second owner had it since 20 hours at a small farm and stored under a car port or barn. Looked good and the price was right so I bought it. The 4300 will be for sale soon once I fix some minor issues with it.
Dad picked up the 4400 for me and noticed that when you first hit the hydro pedals, it doesn't move unless you give it about 1/2 throttle, then it chatters like it has air in the system. Also runs away going downhill sometimes, but has plenty of power pushing dirt and the steering/loader/hoe all work great. We've worked on a fair number of hydrostatic lawn tractors so decided since the fluid didn't smell the best (suspect it is the original fluid) maybe the plates in the hydro were scored allowing loss of pressure. Pulled those out and weren't too bad, but resurfaced them anyway. New JD hydro fluid, filters, suction screen cleaned, etc. Drives a little better but still not nearly as smooth as my 4300, and still the dead pedal when first started.
It's sitting in dad's garage at the moment 5 hours away, I hope to get it hauled to my place soon and better investigate the transmission.
So, do the symptoms ring any bells?
It is my understanding that the transmission gets charged from the power steering circuit. Since the steering works great (better than my 4300), what does that leave to check?
Thanks! Ryan
/ JD 4400 HST transmission chatters #2
What is involved when pulling out these plates in the hydro? You make it sound like a minor job.
If not one already, better get the service tech manual for the 4300 and the 4400 (all in one anyway).
:welcome: to TBN
You have to split the tractor and disassemble the HST. Not all that complicated (relatively speaking) but it is tedious and does take time.
I plan on getting a manual, what is the best place to order from?
/ JD 4400 HST transmission chatters #4
If it were the later model with the ehydro, I'd say you have the match load switch on and that is how they work. Not sure what else to tell you.
I've driven an ehydro before, I can't imagine why anyone would use that function. It's like you're controlling the transmission with a rubber band.
Started looking through the tech manual, my best guess is a problem with the charge pressure relief valve. Either a broken spring or debris caught under the poppet letting the pressure drop too much at low RPMs, and while the tractor is not running maybe it's letting the oil drain out of the pump. That's making an assumption that the relief dumps to reservoir, which the manual is not clear on.
Now I just need time to check it out :)
/ JD 4400 HST transmission chatters #6
texasranger,
what type of control in your HST? Is it direct linkage from the foot pedal to the swashplate or some form of servo control taken from a pilot pressure? On my Branson it does not feather from start at low RPM's which I suspect is due to the "neutral" valve having to large of a dead band but once moving it moves smoothly.
Does your JD have some form of 'neutral" valve that could be sticking?
The foot pedals appear to attach directly to the swash plate on the pump, no servos or pilot controls that I'm aware of.
When I compare between my 4300 and 4400, it's night and day difference. The 4300 will crawl smoothly out of the garage at idle while the 4400 just sits there with the pedal mashed all the way down. Give it some throttle and it starts moving but chatters. Low charge pressure seems to fit the symptoms.
/ JD 4400 HST transmission chatters #8
Agree that low charge fits the description but it would almost have to introducing air / drawing a vacuum to get the chatter and freewheeling effect.
If charge is fed from steering and the steering works fine that eliminates the pump so will have to determine were the flow is going when it leaves the steering circuit.
good luck
good luck
According to the schematic (which could use a little more detail), the only logical place the charge circuit oil can escape back to the reservoir is through the charge pressure relief valve. It's certainly not leaking externally.
I agree with you that to chatter as bad as it does it seems like it would have to be ingesting air from somewhere, so if the valve looks alright I'll have to get a gauge to check for at least 100psi of charge pressure and see if the oil is foamy at the check port and go from there.
/ JD 4400 HST transmission chatters #10
relief valve.
There are pressure test ports for charge pump and the FWD/REV functions. You should get something
like 150psi for the former, and nearly 6K psi for the latter 2, on relief. You can get at the test
ports thru the hole in the bottom of the housing. It is a tight fit, I know.
/ JD 4400 HST transmission chatters #11
From the 4310 ehydro troubleshooting manual,
(1) Poor Transmission Performance?
Yes - Loss of charge pressure.
Yes - Low hydraulic fluid level.
Yes - Plugged filter.
Yes - Improper current to solenoid valve.
Yes - Solenoid valve malfunction.
Yes - Plugged screens at solenoid valve.
Yes - Worn rotating kit components.
Yes - Parking brake is on.
Yes - Ballasted too heavily.
Yes - Wrong valve installed.
Thanks Kyle.
As luck would have it I talked to my dad yesterday about my theory and explained what to look for. Tonight he called and said after taking out the charge pressure relief valve, it looked like the poppet was sort of off center when he pulled it out. Cleaned out the hole with a magnet and a rag, put it back together and now it drives like brand new! Nice and smooth even at idle. Gotta love it when a theory comes together! Too bad we didn't check that first before splitting the tractor and re-finishing the plates, but only cost us time, some sealant, and $15 for the manual. Now to get it hauled down here and start building my shop :cool2:
Cheers
Ryan
/ JD 4400 HST transmission chatters #13
I'm glad you got it fixed and that it was something simple. Now you have given an answer that might help the next guy down the road.
/ JD 4400 HST transmission chatters #14
I was having the same problems with my 4400. It was jerking, barely lifting lift arms,squealing when operating go pedals.I hate to say this , but my tractor came from a landscaping company and at 1444 hours, the oil screen had never been serviced. It had so much crap on it > There was so much metal chunks and shavings it looked like something had broken. It seems when JD made these tractors, they didnt do a good job removing the scrap metal parts. Anyway, a new filter,gasket and $200 worth of JD hydro oil and she is purring like a kitten.
Sounds like classic oil starvation/pump cavitation, good work fixing it.
I'm not so sure that a significant amount of metal is left in the system from the factory, most OEMs do recommend an initial service to address that. Over time the gears, diff lock, clutches, and bearings all wear and introduce particles into the system, especially if abused. Keep up with filter, screen, oil changes/cleaning and things will last.
/ JD 4400 HST transmission chatters #16
I am sure they all have significant amounts of metal particles in there, left over from manufacturing. I was initially shocked to see what I got out of my new Kioti when I drained the fluid right after I got it new.
These particles don't really cause any problems, however, as they are caught by the filters. Unless/until they overwhelm the suction screen. The JD 4200/4200/4400 has a large suction screen, but they also have a problem with the PTO brake breaking down and shedding excessive amounts of debris into the sump.
2017 CATERPILLAR 420F2 BACKHOE (A60429)
2017 CATERPILLAR...
2012 INTERNATIONAL 4300 4X2 26FT NON CDL BOX TRUCK (A59908)
2012 INTERNATIONAL...
2004 MCI D4500 Bus, VIN # 1M8PDMPA44P056241 (A61165)
2004 MCI D4500...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Peterbilt 567...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
2019 Ligchine Spiderscreed Concrete Screed (A59228)
2019 Ligchine...
