anyway to cover the fel edgefor snow removal so it doesnt scrape my blacktop
   / anyway to cover the fel edgefor snow removal so it doesnt scrape my blacktop #11
I used a 2 7/8" pipe with slot cut in it. Works fairy well. Have used 2 season, looks like it will last for awhile too.
   / anyway to cover the fel edgefor snow removal so it doesnt scrape my blacktop #12
I may use the fel to clear my blacktop driveway...any good way to cover the steel edge of the fel so it doesn't scrape up my blacktop
CVCman: try this: http://johnnyproducts.com/images/JBJr%20shoe/jbjrshoe%20004.jpg
Johnny Scheele makes great products. This snow shoe happens to be a 50" model which should fit your bucket.
Email him first before ordering.
I have a JP bucket jr that I've had for years now. No complaints at all. Good quality construction.
   / anyway to cover the fel edgefor snow removal so it doesnt scrape my blacktop #13
Metal pipe or PVC? If metal, how did you cut the slot? Using a grinder would take a while to cut a 6' slot!
   / anyway to cover the fel edgefor snow removal so it doesnt scrape my blacktop #14
   / anyway to cover the fel edgefor snow removal so it doesnt scrape my blacktop #15
No snow here but, I think if you go with PVC pipe you could just clamp it between a couple of 2x4's and cut a slot with a circular saw. 2x4's would keep pipe from rolling.
Sent from my iPad using TractorByNet
   / anyway to cover the fel edgefor snow removal so it doesnt scrape my blacktop #16
Metal. Don't think PVC would last. I've read that some have opened up the pipe with the slot using a torch. In my case a friend who had one of those two bladed circular saws cut the slot in it for me.
I had two holes in the bottom of the bucket that the previous owner had drilled. Welded metal tabs, bolted on, works decent.
   / anyway to cover the fel edgefor snow removal so it doesnt scrape my blacktop #17
   / anyway to cover the fel edgefor snow removal so it doesnt scrape my blacktop #18
Windcatcher,
Sorry see the website address, now.
   / anyway to cover the fel edgefor snow removal so it doesnt scrape my blacktop #19
I must say that the edge tamer impresses me.
Real smart idea, hope he has a patent.
I welded similar idea for plowing my drive as well as made oversize skids for my blower.
All my gravel problems solved. (and no more sheering of blower pins)
Bobcat T590 (A53317)
2017 Ford F-250 Pickup Truck w/ Liftgate (A56858)
2017 Ford F-250...
2011 Ford F-150 Ext. Cab Pickup Truck (A55973)
2011 Ford F-150...
19010 (A55851)
19010 (A55851)
New/Unused 72inch Quick Attach Rock Grapple Bucket (A57454)
New/Unused 72inch...
2006 Toyota 7FGU60 11,250lb Propane Forklift (A55973)
2006 Toyota 7FGU60...
