pclausen
So I got this 1980's Square D panel (there are 2 actually, but I'm putting this one behind a transfer switch).
Here's the label:
And here's another part of the label, showing the bonding screen between the neutral bar and box. I know I need to remove this.
View of the entire panel. Note that I have already removed the original feeder wires, which entered in the top left corner. I have installed a 2" metal plug there. I have also marked the 4GA ground wire with a green arrow that goes to the ground rod. This will be pulled and connected to the Asco transfer switch instead.
Closeup of the neutral bars. Note how the original installer randomly used both the inner and outer bars for neutral and ground connections. The green arrows are the bars I intend to dedicate to ground. The yellow arrow points to the screw that is bonding the neutral bar to the box. As stated above, I'll be removing it.
Another angle of the neutral/ground bars. I don't see a way to isolate the inner bars from the main neutral bar.
So my plan is to move all neutral connections to the outer bars, unscrew the 2 inner "ground" bars, and drill holes and bolt then directly to the box as seen in the very crude illustration below:
Unless I'm missing something, it would seem that unlike Cutler Hammer, these Square D Q0 panels, do not offer an easy way to separate ground from neutral, thereby not making them an ideal choice for a sub panel in the first place?
Can you suggest an easier method to turn this panel into a sub panel?
PS In case you're wondering what that thick neutral wire still in the panel is, that feeds a 100A subpanel where my 3 outdoor units reside.
Thanks
Here's the label:
Thanks
