Mulching blade for BX 60 inch?
/ Mulching blade for BX 60 inch? #1
bsailors
Houston TX
Kubota BX2350
I really need to find some decent mulching blades for my 60 inch fine cut deck.
Does anyone have any part#'s? I usually use the oregon or stens standard blades, but the thatch is killing my yard.
I did a search and cannot seem to find anything.
/ Mulching blade for BX 60 inch? #2
The dealer told me mulching kits on three blade decks do not work well. I just keep mine sharp and it does ok but not as good as a true mulcher.
If you find some please post the source.
/ Mulching blade for BX 60 inch? #4
I have Meg-Mo blades on my rear discharge ZT 72" deck and I have next to no discharge anymore. The Meg-MO uses a big metal disc with 4 small pivoting blades attached to it. It double cuts the clippings so they are very small and all but disappear. When I cut with my Kubota side discharge there are always clippings to rake. Might be worth looking into. I ordered them factory direct after seeing them at a trade show.
/ Mulching blade for BX 60 inch? #5
The factory mulch kit is crap. I got it for my 60P deck. Took it off and now use the Oregon G6 blades. More frequent cuttings will help keep the thatch down. The G6 will leave a very fine clipping, finer than I was getting with the mulch kit.
Do you happen to have the part# for those blades? That is what I was looking for.
Edit, this one??
Oregon G6 20-9 Gator Mulcher Blade / 396-612
/ Mulching blade for BX 60 inch? #7
Do you happen to have the part# for those blades? That is what I was looking for. Edit, this one?? Oregon G6 20-9 Gator Mulcher Blade / 396-612
My mistake.. I have a 60 on my ZD zero turn, the one on my BX is the 54P. I believe 396612 is the correct blade for yours.
Giyi HWG72 (A60463)
Giyi HWG72 (A60463)
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
12FT X 20FT STEEL CARPORT (A58214)
12FT X 20FT STEEL...
2019 BOBCAT T740 SKID STEER (A62129)
2019 BOBCAT T740...
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A59823)
2017 FORD F-350 XL...
2017 Loat 22ft Tilt Trailer (A59231)
2017 Loat 22ft...
