Mulching blade for BX 60 inch?
   / Mulching blade for BX 60 inch? #1
bsailors
Houston TX
Kubota BX2350
I really need to find some decent mulching blades for my 60 inch fine cut deck.
Does anyone have any part#'s? I usually use the oregon or stens standard blades, but the thatch is killing my yard.
I did a search and cannot seem to find anything.
   / Mulching blade for BX 60 inch? #2
The dealer told me mulching kits on three blade decks do not work well. I just keep mine sharp and it does ok but not as good as a true mulcher.
If you find some please post the source.
   / Mulching blade for BX 60 inch? #3
you don't use just mulch blades, there are also baffles. I'd suggest calling our parts dept @ 877-260-3528.
   / Mulching blade for BX 60 inch? #4
I have Meg-Mo blades on my rear discharge ZT 72" deck and I have next to no discharge anymore. The Meg-MO uses a big metal disc with 4 small pivoting blades attached to it. It double cuts the clippings so they are very small and all but disappear. When I cut with my Kubota side discharge there are always clippings to rake. Might be worth looking into. I ordered them factory direct after seeing them at a trade show.
   / Mulching blade for BX 60 inch? #5
The factory mulch kit is crap. I got it for my 60P deck. Took it off and now use the Oregon G6 blades. More frequent cuttings will help keep the thatch down. The G6 will leave a very fine clipping, finer than I was getting with the mulch kit.
Do you happen to have the part# for those blades? That is what I was looking for.
Edit, this one??
Oregon G6 20-9 Gator Mulcher Blade / 396-612
   / Mulching blade for BX 60 inch? #7
Do you happen to have the part# for those blades? That is what I was looking for. Edit, this one?? Oregon G6 20-9 Gator Mulcher Blade / 396-612
My mistake.. I have a 60 on my ZD zero turn, the one on my BX is the 54P. I believe 396612 is the correct blade for yours.
(2) UNUSED FUTURE 10' SLIP-ON FORK EXTENSIONS (A60432)
(2) UNUSED FUTURE...
2019 CATERPILLAR 239D3 SKID STEER (A60429)
2019 CATERPILLAR...
Kubota ZG222 (A60462)
SWICT 66" SKID STEER BUCKET (A60430)
SWICT 66" SKID...
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
CATERPILLAR 950M WHEEL LOADER (A60429)
CATERPILLAR 950M...
