How's your Farmtrac doing?
/ How's your Farmtrac doing? #21
Mine had 225 when I bought it,it now has 228 its a loud
/ How's your Farmtrac doing? #22
Have about 520 hours on my FT60. Still running strong since new in 03.
/ How's your Farmtrac doing? #24
The 555DTC had mismatched tires on the front causing a strain on the 4WD gears. You should use the 4WD sparingly and only on a sod or dirt surface. As far as the brake boots go, they all went bad very quickly. Maybe they are made out of better material now.
/ How's your Farmtrac doing? #25
A bad injector can make a helluva metallic sound when they stick.
2016 JCB 510-56 10000 LB Telehandler (A64047)
2016 JCB 510-56...
Sellick S80 (A60462)
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
213324 (A64279)
213324 (A64279)
2014 FREIGHTLINER CASCADIA 113 S/A DAY CAB TRUCK TRACTOR (A59912)
2014 FREIGHTLINER...
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
