Finally ... Talked about it ... been talking about ... got a start!!!
   / Finally ... Talked about it ... been talking about ... got a start!!! #1
blueriver
Super Member
S.E.Oklahoma
JD 5520 Montana 4340 Farmall Super A Montana 5720C
I have threatened to build one for along time ... so many out there just hard to decide which one, how big ... soooo I just decided its time go ahead and draw it out, cut it out and just weld the darn thing together. I'm doing this between customer jobs and other builds so it may be a few weeks before its done.
20150803_133908_resized.jpg20150803_133914_resized.jpg20150806_141118_resized.jpg20150806_141130_resized.jpg
   / Finally ... Talked about it ... been talking about ... got a start!!! #2
Looking pretty darn good so far, very good work.:thumbsup:
   / Finally ... Talked about it ... been talking about ... got a start!!! #3
Looking good:thumbsup:
   / Finally ... Talked about it ... been talking about ... got a start!!! #4
Great start, it's looking good.
   / Finally ... Talked about it ... been talking about ... got a start!!! #5
:thumbsup: How wide? Lid, none, one, two?
   / Finally ... Talked about it ... been talking about ... got a start!!! #6
Great...... Now I'm in the "can't see the pictures" club. Whatever it is congratulations on just doing it!
   / Finally ... Talked about it ... been talking about ... got a start!!! #7
We see those on CL up here in the 900-1000 range, 72" wide. By the time you are done with that, time and material, what would the cost be ?
Thanks everyone ... Its 72" wide and will have two lids ... and if you can't see the pictures its a grapple!!!!
I'll have right at $700 in material ... plus my time ... if I could have found a heavy duty well built one in the $1000 range I'd snatch it up. However I'm using T1 hardened steel ... alot of them I look at also cut corners on the hitch design ... no backing plates and the SSQA top only goes over each side about 18" ... I also up'd the cylinders to 3" instead of the 2" that most have.
I always get accused of over building .... oh well ... its probably 100 lbs heavier than anything on the market that you'd compare to. Which can be a downfall for smaller tractors.
I got a little time between customers to get some more done ...
These are the hydraulic cylinder mounts, cut to fit the top rail as well they are cut to fit the top portion of the SSQA ... they also drop over the front rail not only will they really support the action of the cylinder, they tie all of it together.
This is the SSQA bottom where the pins lock in ... instead of just welding to the frame I put a 3/8" by 4" plate the complete run of the hitch ... this ties into the bottom rail, each tine as well as the hitch mechanism
A view from the front. I'm also doubling the jaw brackets ... probably could have just used one with a grade 8 bolt but I think two will be better with a machined pin.
Just another view ... I added a 3/8" by 2.5" flat along the top behind the angled top of the hitch ... this tied in the top rail into the top of the tines ... Just a little more support.
   / Finally ... Talked about it ... been talking about ... got a start!!! #10
BR,
What's your tine spacing? Ya know I drool everytime I see photos of your plasma cutting.
hugs, Brandi
BR,
hugs, Brandi
Hi Brandi ... 8" OC. Its hard to make up ones mind what the "perfect" spacing is ... I'll have to let u know when I get to using it if that 8" is the magic number !!!!!
   / Finally ... Talked about it ... been talking about ... got a start!!! #12
Mine is 9 inches and it is too wide. If I had one made, it would be 7 inch spacing, or even 6 inch spacing. Picking huge limbs are a breeze. It's all my small branches that are a pain to pick up.
hugs, Brandi
hugs, Brandi
I'm thinking of making "removable" short tines to put in between ??? Should not be to hard to do ... round the front to match the pipe ... and notch the back to fit the frame simply slip them in.
   / Finally ... Talked about it ... been talking about ... got a start!!! #15
Looks good! My "lids" are further apart. I like the idea of removable tines. More tines equals more small limbs being picked up. But more tines also means more dirt being picked up too.
hugs, Brandi
   / Finally ... Talked about it ... been talking about ... got a start!!! #16
<img src="http://www.tractorbynet.com/forums/files/build-yourself/438869-finally-talked-about-been-talking-20150827_140244_resized_1-jpg"/>
Don't you think the lids are close??
   / Finally ... Talked about it ... been talking about ... got a start!!! #17
Looks great! Did you powder coat? The lids look a little close, but should be totally functional. What kind of plas table/machine are you running?
Good work!
Regards,
Chris
Good work!
Regards,
Chris
Yes they may be a little close ... wont nothing escape!!!!! I'm running a Hypertherm PM 65... My table is 5x10 ... I upgraded the entire system just a couple months ago ... went with candcnc ethercut ... that gave me DTHC and feather touch
   / Finally ... Talked about it ... been talking about ... got a start!!! #20
Nice build:thumbsup:
207275 (A52708)
207275 (A52708)
CATERPILLAR 108" WHEEL LOADER RAKE (A52707)
CATERPILLAR 108"...
Massey Ferguson 9250 (A61307)
Massey Ferguson...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A61306)
2021 Takeuchi...
42" HANG-ON WHEEL LOADER FORKS (A60429)
42" HANG-ON WHEEL...
2020 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A60429)
2020 PRINOTH...
