My first problems with my CT235
/ My first problems with my CT235 #1
lilranch2001
Super Member
Bobcat CT 235
Recently I had my first two problems with my Bobcat
first was a hydraulic leak on the FEL loader joystick control valve, which when I have more time I will detail completely, but for now on to my second more pressing issue
During the summer I started a dirt moving project and used a tank full of fuel.
It seemed to go down at its normal rate, when I felt like it was due for a fill up I went and purchased my normal 5 gallons
I put it in, and started the tractor and to my surprise I still had an empty tank on the gauge.
Again I used (by hours what I assumed would be about 5 gallons) filled up my can again, and she is still showing empty
Anyone have similar issues, and know where I should start in troubleshooting it?
:confused3:
/ My first problems with my CT235 #2
:confused3:
Fuel gauges are pretty simple, a meter (the gauge) wiring, a variable resistor and a float and the source of voltage. Break out the VOM and start checking. Should not be too bad.
Thanks James
/ My first problems with my CT235 #5
Hopefully this will help a bit. Yes the 7.5 amp fuse, that runs the gauge cluster for every thing else. Does the temp gauge work? If so this fuse is not blown, Does the 4wd lamp light? if so this fuse is good. Be sure to check ground wire on the fuel sender too. The F/G is the fuel gauge You can see that there is a voltage coming in from the top of the fuel gauge from the fused buss, then a series circuit thru the sensor variable resistor to ground.
/ My first problems with my CT235 #6
.View attachment 438749
Now the above is a sure nuff helpful post. :thumbsup:
yea, everything else on the guage cluster seems to be working
I haven't had a chance to look for my VOM yet, and knowing me it could be most anywhere........
/ My first problems with my CT235 #8
Your float is probably sticking. Either pull the unit and free it up or you can try using a bent piece of wire and wiggle it around and free it. It happens to me about once a year when i run the tank really low.
I was wondering if it could be as simple as something like this, but was afraid if I tried I may screw up the float.
I will give this a shot first
Thanks for everyone's help
:thumbsup:
It seems it was that simple
Thanks!
/ My first problems with my CT235 #11
Thanks!
So it is working OK now then.? Just don't let the fuel get that low again I guess. Well anyway you know more than you did about the fuel gauge system:)
I jiggled it around and the gauge came up to about a 1/2 full, and after about a couple hours of running it is down to 1/4
I am going to get 5 gallons now, that should top it off, lets hope it reads full then
:thumbsup:
Filled it with fuel and she is reading full now!
Yea!
I wonder if all the Bobcats have this issue running them low
I think I had to put 6 gallons of fuel in that time, and I thought that the tank held 7 gallons
2017 Case CX145D (A60462)
2017 Case CX145D...
2006 Ford F-150 4.6L V8 Gasoline Engine (A61573)
2006 Ford F-150...
2018 LIEBHERR A900C LITRONIC WHEELED EXCAVATOR (A63276)
2018 LIEBHERR...
2019 Mercedes Sprinter 2500 Cargo Van (A61573)
2019 Mercedes...
2017 Ford F-450 Liftmoore 5000W 2 Ton Crane Service Truck (A61573)
2017 Ford F-450...
HONDA WP40X 3" WATER PUMP (A64281)
HONDA WP40X 3"...
