Deck footings with a backhoe?
/ Deck footings with a backhoe? #1
Chvypowa
albany, ny
2013 BX25D
We are looking to put a deck on the house in the next month. I have a BX25 and thought about using the backhoe to dig the footings instead of buying a post hole digger. Has anyone attempted this? Would it work?
Thank you
/ Deck footings with a backhoe? #2
Would it work?
Yes.
Would it work well?
No.
If you can, try renting a PHD, either for your tractor or a towable one. The 1 and 2 man augers beat people.
/ Deck footings with a backhoe? #3
It'll work. All you need is reach to get deep enough. Dig hole, place, align and support sona tube, back fill a bit, check sona tube alignment and complete backfill.
/ Deck footings with a backhoe? #4
/ Deck footings with a backhoe? #5
Sure it will work, but you end up with a very large hole in the ground that you will have to either fill with concrete, or do as already suggesting and use a sono tube, then back fill. Problem with back filling is getting the soil around the sonotube compacted, which will never happen.
/ Deck footings with a backhoe? #6
It will work but i would use bigfoots for a solid base. Or you could pin sonotubes on a footing:)
Ive done both and bigfoots are easier imo
Oh ya and use rebar. Good luck
/ Deck footings with a backhoe? #7
No problem. I did it for a friend, and the soil was quite sandy, so it was easy dig, and very fast. Also, you don't really need the backfill to be compacted, because all the weight will be at the bottom of the hole. Just make sure that the bottom of the hole is undisturbed soil, and that you put some gravel before you pour the sono tubr.
/ Deck footings with a backhoe? #8
And in Albany that's 50" to 60". https://www.decks.com/deckbuilding/Deck_Footing_Frost_Depth_Map
Practice digging a 60" deep hole someplace in your yard with the same soil and your equipment first. A lot depends on the soil type, rocky, sand, clay can all make a great difference.
Your saying that an auger can handle soil/rocks the hoe can't?
Few years back I dug a few sona tube holes for my Daughter. JD #7 backhoe and five foot deep. No problems. No big piles of dirt left. No big settlement holes. Didn't take long and I'm somewhat challenged with the hoe controls.
Don't need a big hole. Just a sona tube width trench that's vertical at the start and just about the same at the end.
Thanks guys! leaning towards doing this with the bigfoot tubes. I'll keep you posted
/ Deck footings with a backhoe? #10
speaking from experience, your BX will be at more of an disadvantage than my TC33 with woods hoe.
To dig a nearly sq hole you have to work the bucket "straight down" in order to do this you have to rely on the weight of the machine to "push" the cutting edge into the ground before you can curl the bucket toward you and then lift straight up. There is no other way to dig a small hole than useing this method, and it sucks!
if your soil is sandy the best you can hope for is a bit over 1:1 slope meaning for a 50" deep hole your looking at 4'x4' top.
as for your project... if you had 2 footings to do, id dig them with the hoe. if you had like 6 or 8 to do id rent the auger.
/ Deck footings with a backhoe? #11
Id say try it with the BH first, and if it aint working well, get something else.
The issue with a PHD and your machine is depth. A PHD made to fit your BX hitch is gonna have issues getting the depth you need.
/ Deck footings with a backhoe? #12
I used my backhoe to dig the footings for my deck. No problem, and I have an auger. Just dig down and compact the bottom where the sonotube will sit. Do this with water and a tamper from the hardware store, or a piece of 4X4. Set the tube and backfill, compacting as you go. This method gives you a very nice bottom, no cave in and a tightly fitting sonotube. Plus you can adjust the position of the tube to get it in the perfect spot.
/ Deck footings with a backhoe? #13
I recently dug six holes for concrete piers to hold I beams for a 25'x50' shed with my backhoe. I have a 24" bucket and the holes ended up much bigger than I wanted. It is hard to dig small holes with a backhoe.
/ Deck footings with a backhoe? #14
Not only would a backhoe work I would say that you will want to use a backhoe because you will want to use bigfoot type footings. Otherwise you will want to calculate both live and static loads on each post and then determine how much weight your soil will support so you will know how much surface area (what size diameter) you will need. I have lots of rocks around here and use them. The nice thing about using a rock is that you can drill holes in them and epoxy rebar into the holes. Rocks with holes hold rebar much nicer than sticking them onto the dirt.
/ Deck footings with a backhoe? #15
Yes, it will work, just not ideal. Be careful not to over excavate. Big foots are nice, but are overkill on a small deck. Stay out of the hole less it collapse and becomes your grave.
/ Deck footings with a backhoe? #16
Around here decks are becoming almost all done with screw piles. I forget the price per pile, but it was such that the convenience it provided far outweighs the cost. The screw pile installers machine is about the size of a quad. It can for into most urban backyards easily. They install it to a predetermined torque to twist the pile. And once the pile is in you can immediately begin building the deck, no waiting for concrete to cure.
Sent from my iPhone using TractorByNet
/ Deck footings with a backhoe? #17
I did it for a few posts at my home and it worked well, with the caveat that I was placing 24" diameter footers, so the large diameter hole was not a problem for me. If you are placing smaller footers, the hole might get a bit large, as others have said. When I build my outbuilding, I will be purchasing a post hole digger. If you spend $500 on a PHD and use it for one project, you could probably sell it for $350-400 when you are done, so cheaper than renting. That is my plan.
/ Deck footings with a backhoe? #18
Depends on scale of the project and the timeframe...for a porch I just built, I dug 5 12" footings (4 with bigfoot equivalent) with a shovel over a few afternoons. A small deck with two 8" footings went in with a 6in. "Iwan" post hole auger*. It was slightly smaller than the hole, but if I jammed the tube form in, it would show me where I needed to take a little more off.
And of course, it depends on your soil type. Being on sand rather than clay, loam, or ledge made all of these go in pretty easily. One good fist sized rock would have me switching to other options, like a the traditional two-handle digger, much as I despise them.
* Like this:
Seymour Post Hole Auger, Iwan Pattern, 6-In.: Model# 21306 | True Value
I put a 3' pipe extension in mine, so that it starts digging with the handle just over my head, and I'm done when the handle reaches waist high, rather than having to bend way down.
But really, sometimes the easiest answer is to just get out the hand tools and go at it.
/ Deck footings with a backhoe? #19
/ Deck footings with a backhoe? #20
Apparently I'm in the minority, I'd go for the backhoe without question. I've lost count of how many sonotubes I've done over the years with a hoe...probably a couple hundred. So much so that if my choices were using an auger I had vs renting a backhoe (or mini-ex) I'd rent.
Now if you had a large auger on a skid steer or mini-ex, that would be I different story. In my mind, a PHD on the back of a tractor is all but useless once you've run one on either of the other 2 machines. The control and down pressure makes you wonder why you ever bothered to fight with a PHD on a 3pt hitch.
You bought the BX25 for a reason I presume. Why not use it for what it was meant for? Get out there and dig some holes! :)
2005 20 Ft. Grady-White Boat with 25 Ft. Float-On T/A Boat Trailer (A64557)
2005 20 Ft...
(4) Texas Built Stand Alone Livestock Panels (A66408)
(4) Texas Built...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A65583)
New/Unused...
2023 JOHN DEERE 333G SKID STEER (A65053)
2023 JOHN DEERE...
1966 Hale Livestock Trailer (A66285)
1966 Hale...
AUCTION STARTS HERE @ 9AM (A65053)
AUCTION STARTS...
