   / Share Pics of People Hauling or Towing Something Wrong #2,231
If you get it hooked up a Kubota will pull it. You might have to take it easy on a JD. Brand bashing aside the Kubota is geared low and diesel powered.
I had an aluminum ambulance cab filled with tools on a 16 ft utility trailer from an auction. I parked it in a low spot and my truck could not get traction. I backed up with my Polaris ranger XP and it pulled the trailer right out. Back end was squatted with probably 500+ pounds of tongue weight. It wasn't pretty but it did it. I later scrapped the ambulance cab and it was over 3,000 pounds just by itself. I"m sure the load was well over 5,000 pounds. Pretty amazing what some of those machines can do.
   / Share Pics of People Hauling or Towing Something Wrong #2,232
Watch the belts on that Polaris, what a pain when they go !
   / Share Pics of People Hauling or Towing Something Wrong #2,233
I pull in and out our two companies airplanes with a Polaris Ranger. It has a Reese hitch in the front in place of the winch. One plane is 10,495# and the other is 24,000#. It has no trouble even in the winter tanks to 4x4 and 8 40# weights in the bed as needed.
Chris
   / Share Pics of People Hauling or Towing Something Wrong #2,234
The old duramax needs some new shocks
   / Share Pics of People Hauling or Towing Something Wrong #2,236
Can't say whether it needs new shocks but it does at least need new rear springs or a load distribution hitch. The 7K trailer is probably overloaded too.
The Ford can't be over 7k. The duramax is about 9k with all tools in it and hooked to a 16ft landscape trailer
My guess is that the Ford isnt more then 4k. It's only got a little straight six 4 speed
but the shocks are actually bad
   / Share Pics of People Hauling or Towing Something Wrong #2,237
I didn't know it was yours.
a 7K trailer can't haul 7K. Maybe could haul 4500-5000 depending on trailer weight.
New rear springs and a load dist. hitch would prevent the Dmax rear from squatting so much.
   / Share Pics of People Hauling or Towing Something Wrong #2,238
Yep. When I go to get gas (with 5-6 5 gallon cans in the back of the truck) I ALWAYS strap them in. No chance of them coming through the back window for a visit that way.
Aaron Z
Thought i'd share this one.When I dint have a truck, I got 5 gallons of gas in a can and was placed on the floor behind the front seat. It had a large fill hole.. anyways someone cut me off in the parking lot, and the can fell over , and spilled about half plus before I realized it... I stopped and stood it upright and all I could do was to drive home with the windows open and the heater on ,using a magazine out the window to suck air in and also I would take breaths out the window and hold it. Then once home I took a chisel and hammer sliced a drain hole in the floor and then ran the water.
then closed windows and bake dried it in the sun..LOL
   / Share Pics of People Hauling or Towing Something Wrong #2,240
A match would have dried it out quicker :D
2019 CATERPILLAR 259D SKID STEER (A52705)
2019 CATERPILLAR...
78" ROCK BUCKET (A52706)
78" ROCK BUCKET...
2019 Komatsu WA380-8 Wheel Loader, S/N A75147, PIN# KMTWA130TKNA75147, Turbo Diesel Engine, Komatsu (A59076)
2019 Komatsu...
LOT: (80 approx.) Gallons of Chevron Delo 400 XLE SB SAE 15W-40 Synblend (A59076)
LOT: (80 approx.)...
WOOD GRABBER FOR MINI EXCAVATOR (A58216)
WOOD GRABBER FOR...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52709)
KNOW BEFORE YOU...
