Kioti LK3054 PTO
/ Kioti LK3054 PTO #1
CaliEscapee
Warrensburg, MO
Kioti LK3054
I'm pretty new to this tractor thing, but I bought a decent sized piece of land and needed one to help take care of it. A year ago I picked up a LK3054 and this spring my PTO stopped working. I took it apart and found the PTO shift fork broken. Today I got the new fork, installed it and put everything back together but this is the first time I've ever done anything like this and I'm a little worried everything went back together a little too easy.
Before I put the 27L of transmission fluid back in or tear it open again to recheck my work is there a safe way to check that the PTO is working now? I am getting a nice mechanical snick-snick-snick when I move the lever but the PTO turns freely with the extra sound of gears turning when the lever is in the engaged positions. Is this right or should the PTO be hard/impossible to turn by hand when engaged?
/ Kioti LK3054 PTO #2
I have the same tractor and with the tractor not running and shift the selector to either of the pto ranges, you should not be able to rotate the pto shaft, unless the clutch is completely depressed
/ Kioti LK3054 PTO
Thanks. I tore it open again this evening and after a little searching found a ring that couples the shafts together fallen in where I couldn't see it. After I put that on and did a little adjustment to get the shafts to mesh up the PTO locked up when in gear.
After I got everything back together I filled up with fluid I gave it a test run. It grinds trying to engage the PTO but works once engaged. Now I think I may have to play with the clutch engagement and hope I don't have to do a clutch replacement.
/ Kioti LK3054 PTO #4
It sounds like an adjustment; I had to adjust my clutch so there is about 3/4" of an inch free play at the pedal and I always wait several seconds with the clutch pedal fully depressed before attempting to engage the pto to prevent the grinding
/ Kioti LK3054 PTO #5
Can you tell me where you found instructions for tear down and rebuild. Having the same problem. TIA
/ Kioti LK3054 PTO #6
/ Kioti LK3054 PTO #7
Good Morning Everyone..
Did a search and found this thread. I ran into the same issue yesterday. I need a service manual and probably the shift fork.
Woods 72" Brush Cutter (A64047)
Woods 72" Brush...
2018 CHEVROLET TAHOE (A66091)
2018 CHEVROLET...
2013 Chevrolet 3500 Dually (A62613)
2013 Chevrolet...
2013 WINSTON AP22024AL-DC T/A 24FT TRAILER (A66091)
2013 WINSTON...
OK TRUCK & TRAILER SALES PRESSURE WASHER TRAILER (INOPERABLE) (A67714)
OK TRUCK & TRAILER...
2012 INTERSTATE TRAILER 28 T/A GOOSENECK TRAILER (A67714)
2012 INTERSTATE...
